Old August 26th, 2017, 15:37
Mikep_86441 Mikep_86441 is offline
Going Through a Beater XJ 4.0.
Used my old smog machine of 30 years, to check for head gasket leaks into the cooling system. This machine is super sensitive to exhaust emissions. Although I had to do a lot of repair work to the machine first. Now it runs great.
The MT2500 Scanner made it obvious that the O2 sensor was bad. I'll double check the sensor wiring too make sure.
The XJ overheats easily. Engine compartment is coated in rust. I'll probably rod out the radiator.
Here is the video I shot of sniffing the overflow tank, and shooting temps of the radiator tanks.
https://youtu.be/ipxG9s8gb0U
Old August 29th, 2017, 07:16
90xj06's Avatar
90xj06 90xj06 is offline
Re: Going Through a Beater XJ 4.0.
my guess is that engine needs a good flush and maybe a radiator. you got some boiling coolant
Old August 29th, 2017, 15:42
For certain! Didn't help unfortunately.
Today I got about 60% through rodding out the radiator. At least 10% of the tubes were plugged, so far. I think it's the original 1988 radiator as it's all brass with plastic tanks. The bottom 1.5 inches of the center section was covered in debris that might block some air flow. I'll put in a new thermostat too since it's far easier to do with the radiator out of the vehicle. Probably should inspect the water pump too.
Old August 30th, 2017, 22:37
Re: Going Through a Beater XJ 4.0. Rodding Out the Radiator.
Started rodding out the radiator of the XJ. About half way through the entire process. Here are a couple of videos of some the work. Not sure if the theory I mention in the beginning of video 1, 'holds water'.
https://youtu.be/f1cwafYjS4Q
https://youtu.be/ITfuQIjE1Wk
Old August 31st, 2017, 07:32
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
You have far more motivation than i do.
I spent the 100 on a spectre cu1193 rad and converted to open cooling.
Old August 31st, 2017, 15:42
Re: Going Through a Beater XJ 4.0. Radiator Rodding Part 3.
They're even cheaper on Ebay for the same brand. So I hear you!! I enjoy a challenge. I'm trying to find an end tank with the radiator cap on it so I can convert this radiator.
Here's part 3. https://youtu.be/_j1nu6dd0tw
Old August 31st, 2017, 19:52
NAXJA Member 4950
When you go looking for another tank make sure it has the hole for the temp sender.
That's whats nice about the cu1193, its sold as a universal xj radiator so it has all the fittings.
Old September 3rd, 2017, 17:23
Re: Going Through a Beater XJ 4.0. Radiator Final Prep.
Radiator header prep plus other misc prep for reassembly in this video.
The 91+ and Renix radiator tanks are the same. They just have a couple of parts that need to get transferred from the older tank to the new. Both parts are external bolt on's. Piece of cake.
Took off the thermostat housing from the engine, and it broke apart in in my hands. Picked up a new one for the 91+ Cherokees so a petcock can be installed to maybe help burping the cooling system.
Here is radiator rod out video part 4.
https://youtu.be/NVVYm9xlGsI
Old September 12th, 2017, 14:57
Re: Going Through a Beater XJ 4.0. Misc Updates.
Next step is to replace the water pump, while it's easily accessible. It looks like cast iron so it might be original like the heater hoses are. New pump is in house already. Along with a new thermostat and housing with petcock valve.
The new gaskets for the radiator tanks are far too thin and a slightly different shape, although still rectangular. Vendor is checking stock for a fatter wall gasket. The trans cooler gaskets look right. Can't wait to have a radiator with a cap on it!! Also have new trans lines to replace seriously weather checked ones.
The tool to compress the spring at the top of the steering column arrived today. Also had to order the turn signal stalk. Half of it was broken off with wires hanging out. Can't wait to get this the column fully re-assembled !!!
Took yesterday off and looked at a semi local XJ for sale. No title and complicated too. Nice shape. Disassembled motor still in chassis. Very long shot.
Old September 18th, 2017, 16:15
Been dying to get the radiator back together. Gaskets from a CA vendor both times don't match the original. So more searching. Backup plan is to re-use the original gasket with 500 degree silicone to seal it all up.
New water pump, thermostat with bleed port, and thermostat housing with petcock valve are now installed.
Once this beater is assembled and running again, testing for overheating and driveability will make the jeep ready for engine teardown to locate the source of the engine noise.
Old September 19th, 2017, 10:54
90xj06's Avatar
let us know how it goes.
Old September 19th, 2017, 19:14
You bet !!
Old September 19th, 2017, 19:29
Talked to another radiator shop and the guy said if you can't get the right gasket, just use silicone. I've got 500 degree silicone. I recon that's where I'm going.
The radiator is the only part missing for a running vehicle. In the a.m., I'll try and get the tank mounted to the radiator. The silicone only says 15 minutes of working time. Then 24 hours of cure time. So pressure testing the radiator won't occur for 24.25 hours after assembly. Sigh.
Found the track rod end is sloppy today, because the steering works so well now. One of those next weak link things. Nice to have a new turn signal stalk.
Once all of this is done, we want to drive the old girl around for a couple of days to check for overheating. Then pull it into the garage to take the valve cover, head, and oil pan off to find out what's making so much racket.
Old September 23rd, 2017, 17:20
Re: Going Through a Beater XJ 4.0. Radiator tank.
Almost 2 weeks of headaches has slowed me way down.
Both of these videos are about the radiator tank. Getting closer.
https://youtu.be/t9CdGaCivLo
https://youtu.be/z7PWRCjMnhQ
Old September 26th, 2017, 04:00
The radiator supply shop in SoCal was on the phone with me probably an hour yesterday. The tank that holds the transmission cooler, has 3 different sized gaskets, it turns out. Basically, 3 flat o-rings you might say. One of them they sent me already. The other two they don't carry and can't get.
So I ordered a small sheet of 1/16 thick high temp silicone gasket material to cut new gaskets from. It won't get here for a week.
The tank gasket that looks like a giant o-ring, isn't available either. Another shop told me they just use silicone to seal the old gasket with. So I will, with 500 degree silicone that's already here.
If I can find some large rod or tubing I'll make some punches to cut out the gaskets. I get the feeling this won't be my only XJ.
I sure enjoy doing projects like this. This one is just taking longer.
beater! ehall North Atlantic Chapter 631 February 14th, 2018 18:25
Beater XJ itrack Modified Tech Discussion 7 April 1st, 2011 10:02
Who's got a Beater Rig? Letterman Sierra Chapter 10 November 6th, 2010 12:52
My new beater hollywood32 SoCal Chapter 11 March 9th, 2007 18:34
beater? skunkman Tow Rigs and Trailers 2 October 10th, 2003 08:26
