Old August 16th, 2017, 15:34
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Power steering return line Burst on the trail
Power steering return line burst on the trail.
All I had to keep the reservoir charged was 10W 30, will this cause any issues?
Also to fix this I had planned on cutting the metal line and adding fuel line hose with hose clamps. sound fair?
does the ID matter for the return line?
Kind of got to get this fixed right now haha
Old August 16th, 2017, 16:43
old_man's Avatar
old_man old_man is offline
Re: Power steering return line Burst on the trail
That is a bit thicker than power steering fluid. The return line should have virtually no pressure on it, so unless something got plugged, there is no reason for it to burst.
I would really recommend flushing the hole system and getting back to PS fluid.
I will look when I get home, I may have a used return line.
I have run transmission cooler hose with barbed fittings for a return for decades. It has to be heat rated, normal braided fuel line hose will crap out over time.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old August 16th, 2017, 17:18
dan1977p's Avatar
dan1977p dan1977p is offline
Re: Power steering return line first on the trail
You can drive without power steering. I'd be surprised if the oil actually worked but doubt it would damage anything short term
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old August 16th, 2017, 17:35
Thanks! An old line would be preferable but some fix is happening tonight.
The oil it worked for getting home. I know from another recent escapade how crappy it is without power steering.
I was more worried about the pump spinning dry.
The line seems to have rubbed a hole through as it rests on the steering column.
Old August 16th, 2017, 18:46
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Pump dry = BAD
Like previously stated, flush with power steering or, in a pickle, automatic trans. fluid.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old August 16th, 2017, 19:46
JeepNoob JeepNoob is offline
Yeah, you have an automatic transmission, don't you? Ford specifies ATF for their power steering systems and has for some time. But like others said, fix line proper-like, flush system with power steering fluid, bleed.
Old August 16th, 2017, 20:43
old_man's Avatar
Finally got home. I had a steering gear with both hoses, but the return hose had been cut in half. Go figure
Loveland, Colorado
Old August 16th, 2017, 21:17
No problem, I thank you kindly for checking. I ended up cutting the metal and adding fuel hose. This as I found out after was not necessary because the metal line is clamped into the original hose.
Oh well, fixed for now. Maybe A replacement part would be smarter for long term.
Old August 16th, 2017, 21:21
md21722 md21722 is offline
The hoses are cheap at NAPA. It's probably more expensive in gas to try get a used one from a member.
Old August 18th, 2017, 10:45
four_shot's Avatar
How 'bout it Gonzo
Chances are that your repair will hold up for the long term. Just make sure its not chafeing on any parts.
4shot
Old August 18th, 2017, 10:57
8Mud's Avatar
8Mud 8Mud is offline
I found a place that sells fork lift hydraulic hose. The stuff that goes up and down on the drum when the forks are raised. Stuff lasts forever, costs a bit but a couple of yards will last for numerous repairs on tranny lines and whatever.
The only real difference between engine oil and most hydraulic and trans oil is the additives and the purity.
Power steering return line 4x4JeePmaNthINg OEM Tech Discussion 13 August 12th, 2017 08:13
Source for Power Steering Return line Fitting beer_goggles_009 OEM Tech Discussion 2 October 24th, 2010 20:42
Power Steering return line CharlieMopps OEM Tech Discussion 4 June 12th, 2009 15:46
Power steering return hose CharlieMopps Modified Tech Discussion 2 June 12th, 2009 10:59
Power Steering Return Line ID Idiot Wind OEM Tech Discussion 3 July 19th, 2007 14:08
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
