Old August 15th, 2017, 18:56
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Horn doesnt work and ive done all i know to do...
horns dont work
relay clicks every time the button is pushed:
- tried swappin all the relays down there and no go for sound, but they all click.
test light shows fuse is good.
Voltometer says i have power to the wires for each horn.
I jumped the horns to the battery and one works one doesnt.
what am i missing here guys im now lost on what else to do?
Old August 15th, 2017, 19:22
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: Horn doesnt work and ive done all i know to do...
Use your middle finger?
So when you press the horn button, you get 12v between the two wires at the horns? But neither one sounds?
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old August 16th, 2017, 00:24
oddly i get about 12v without pushing the horn.
i probed the wiring snap/plug and grounded to a frame bolt= about 12
Old August 16th, 2017, 04:49
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
All the horns need is power and ground. Bad ground ? It is possible that they are rusted inside and you need some new horns.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old August 16th, 2017, 07:19
JohnX's Avatar
Sarge <3 Ben
What year is the jeep?
Johnx is #1
Old August 16th, 2017, 16:18
jeep is a 99.
I tested each horn jumping it to the battery. i clamped the ground to the bracket of the horn similar to it being attached to the body. Then i jumped power to the clip on the horn.
as i said one worked, one didnt, but i cant see why the heck its not working when installed.
also why would i be getting 12v to the wire without the horn button being pushed?
Old August 16th, 2017, 18:59
JohnX's Avatar
Sarge <3 Ben
Doesn't make any sense to me. Horn is just about the most basic circuit on the jeep. The horns are chassis grounded. The power comes from the horn relay. The power into the relay comes from fuse 21 behind the right kick panel. The control side of the relay gets power from the same fuse. The relay is turned on by a ground path through the horn button.
There is no reason that power should exist at the dark green/red wire at the horns. If there was truly 12v positive there all the time, the horn would sound immediately when you plug it in.
Please don't be offended, but are you certain you know how a dvom works?
Johnx is #1
Old August 16th, 2017, 19:22
No offenses taken. Meter set to 20 and bolts, probe to wire, ground probe to frame. 10.59 v at the wire. 12v when running
Old August 16th, 2017, 20:36
JohnX's Avatar
Sarge <3 Ben
That's very weird to say the least.
My next step would be to pull the relay out and check the dark green/red wire for power again.
If you have power with the relay removed, then you have a short to power somewhere along that wire.
If the power goes away, then it was coming from the relay. Then I would check the power and ground that control the relay to see what they show?
Johnx is #1
Old August 17th, 2017, 15:41
Ecomike's Avatar
Ecomike Ecomike is online now
NAXJA# 2091
Horn button shorted, damaged, not installed properly, clock spring wiring in the steering wheel???
Sounds to me like a break in the ground path between the horn guts and the frame to the battery ground post on both!!!!
Hot wire in the harness and to the horns damaged or stuck relay putting power to the horn wire.
Originally Posted by 4x4JeePmaNthINg View Post
jeep is a 99.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old August 17th, 2017, 20:22
Ok new relay today, key off no power to horns with or without the button pushed. Relay does click. Where does this all exit the fuse panel?
Is it the same green wire red stripe?
How would ground separate if it grounded to the frame, and would the relay click if the clockspring ground was messed up?
Old August 18th, 2017, 08:25
8Mud's Avatar
8Mud 8Mud is offline
The basics is the horn button grounds the relay actuator coil. the relay actuator coil has constant power. The relay closes and provides power to the horns, the relay has constant power through fuse 21 at the junction block. The horns ground through the frame.
I have had the horn mount corrode and cause resistance=no ground.
One real oddball I had, horn wouldn't work. I bought a new one, went to install it and discovered my horn was full of water. Dumped out the water and it was good to go.
You really have to probe both sides of any fuse for power or continuity, just because they look good doesn't mean they are good, hairline cracks are hard to see.
Old August 18th, 2017, 09:47
I hit both sides of the fuse with a test light, is this not efficient?
Is it safe to say that if the horn button has the relay clicking then my problem is down stream from there to where the horns mount?
Old August 18th, 2017, 10:40
JohnX's Avatar
Sarge <3 Ben
Yes, I would agree.
You should just need to check power coming out of the relay on the green/red wire, and check continuity of that wire.
Johnx is #1
Old August 18th, 2017, 11:05
8Mud's Avatar
I tend to troubleshoot from easy to hard. Pull the relay and have a close look at the socket with a good flashlight.
If you have no power to one horn check the ground and then the wire. If you have no power to both horns it is likely the wire or more specifically a connector or a splice.
My heat doesnt work and doesnt make sense Doose-doe OEM Tech Discussion 7 September 28th, 2010 23:51
FYI - Speedo Doesnt Work 1988 Cherokoo OEM Tech Discussion 3 March 2nd, 2010 11:30
Horn Doesnt work and Airbag light is on JeepCherokeeGuy99 OEM Tech Discussion 9 March 24th, 2009 16:42
Dimmer doesnt work . why ??? generalleexj Modified Tech Discussion 0 May 6th, 2005 07:45
Aux Fan doesnt work redyouch OEM Tech Discussion 11 February 16th, 2005 16:10
