Old August 10th, 2017, 20:53
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Red loctite, 2 winch bolts broken
So I'm a genius that red Loctite in my winch to my bumper. I spent 10 minutes on one bolt with a burnzomatic propane torch then hit it with a breaker bar in the bolt sheared off. I tried the next bolt heat the crap out of it then loosen tighten loosen Heat and repeat. This goes a little better for a while then the bolt shears off.
I got two bowls left on the front side of the winch what the heck do I do to get these things off?
Old August 10th, 2017, 21:57
Greenz's Avatar
Greenz Greenz is offline
Re: Red loctite, 2 winch bolts broken
Heat has always worked for me.
Maybe give it more time with the torch.
Old August 10th, 2017, 21:58
Re: Red loctite, 2 winch bolts broken, need wiser help
sorry for the phone text illiteracies, the two front bolts are still left. its grade 8 hardware. I tried drilling out one of the broken ones to learn how it would go. uggggh slow slow slow.
does the propane torch not get hot enough? i googled propane torch temp, thought i was good, but it only barley lets these move until they break
Old August 10th, 2017, 22:24
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Try mapp gas. Burns hotter. Anymore than that your looking at mixed gas
Old August 10th, 2017, 22:41
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
torch should work. you don't need that much heat to kill loctite.
try a 1/4" impact. the vibration will help break the loctite free.
a 1/4" one shouldn't be strong enough to snap the head off.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old August 11th, 2017, 17:50
i guess the back two i couldnt get enough heat on even holding the torch on the bottom of the bolt for 10 minutes each.
the front two i was able to get direct heat contact on and less than a minute they came off with the easy out no problem.
Old August 11th, 2017, 19:54
cwyman6 cwyman6 is offline
Better off welding a nut to the broken bolts. Should come right out due to the heat
Old August 15th, 2017, 09:16
burntkat burntkat is offline
NAXJA Member #1145
This.
It's always worked for me.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Red Loctite - Removing Bolts, etc. RAVC1 OEM Tech Discussion 23 October 22nd, 2012 09:48
Grade of Loctite for flywheel bolts? wavingpine11 OEM Tech Discussion 14 September 15th, 2008 23:22
Broken bolts TerryDean Modified Tech Discussion 20 April 3rd, 2007 11:51
Broken bolts every where! glub OEM Tech Discussion 3 October 29th, 2005 18:26
Broken Bolts! PapaPump OEM Tech Discussion 6 March 21st, 2005 05:25
