Old August 8th, 2017, 17:12
97jeepxj1 97jeepxj1 is offline
2" budget boost track bar question
I know on larger lifts people will drill a new mount hole for the track bar but is it necessary for a budget boost using 2" coil spacers?
Old August 8th, 2017, 18:13
TRCM's Avatar
TRCM TRCM is offline
Re: 2" budget boost track bar question
Not at such a low lift level
Old August 8th, 2017, 18:37
That's what I thought just wanted to clarify though
Old August 9th, 2017, 22:52
clydefrog's Avatar
clydefrog clydefrog is offline
I never did. Now using a 4" ish lift with long arms and had to upgrade the track bar. It was never a problem with my 2" BB lift though, you should be good.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old August 10th, 2017, 05:55
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
I just put ZJ coils and 3/4" spacers on my 89 giving me close to 3" and no issues.
suggest a track bar after 2" (1.75) budget boost and death wobble srimes Modified Tech Discussion 18 January 24th, 2009 09:01
budget boost question Swamprat Modified Tech Discussion 0 September 22nd, 2008 13:56
3" lift, Budget Boost, Quick Discos, Rustys Adj. track bar NC4X4boy For Sale: Private Party Only. XJ ITEMS ONLY 13 August 20th, 2006 20:29
Budget Boost Question Farley Modified Tech Discussion 2 April 12th, 2004 16:27
PA: xj stuff (adj track bar, budget boost, uca, sbd) xjennyj Wanted: Private Party Only 5 February 19th, 2004 09:40
