Old August 4th, 2017, 16:23
Mikep_86441 Mikep_86441 is offline
Piston slap?
While I hope for responses to my ignition post, I have a fairly common sound coming from the 4.0 in my xj.
Here is a video I shot yesterday analyzing the sound of the problem.
https://youtu.be/ozllHafEK-c
Old August 4th, 2017, 16:50
Jeep Driver Jeep Driver is offline
Re: Piston slap?
21 minutes...............jeeeesh
What is the point of your post? Dated 2016?
Did you do an in frame?
Big mistake and there is simply no point in it.
You'll be doing it again.
Old August 4th, 2017, 17:19
RCP Phx RCP Phx is offline
Re: Piston slap?
Certainly sounds like rod knock, best to use some form of "stethoscope" to further define it!
Old August 4th, 2017, 17:40
Re: Piston slap?
You didn't watch?
Old August 4th, 2017, 21:15
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Piston slap?
Loose, and leaking exhaust system, that exhaust part near and or attached to the exhaust pipe and the transmission mount is rattling at the frame?????
And or cracked flex plate, but I think it is just the exhaust. Missing bolt??? Bent exhaust pipe?
Check the entire exhaust!!!!
I agree it is not piston slap in my opinion. Sounds like a loose metal part rattling at idle, that goes away when the engine moves and torques as you give it gas.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old August 4th, 2017, 21:23
Re: Piston slap?
When I hit your link.......this is where it took me
https://www.youtube.com/watch?v=ClnTMk7C_tg
Don't know how that happened
Old August 4th, 2017, 21:27
Re: Piston slap?
<iframe width="560" height="315" src="https://www.youtube.com/embed/ozllHafEK-c" frameborder="0" allowfullscreen></iframe>
Old August 5th, 2017, 13:54
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Piston slap?
I thinking flex plate or torque converter bolts.
Old August 7th, 2017, 08:31
90xj06's Avatar
90xj06 90xj06 is offline
Re: Piston slap?
I 2nd the flex plate or torque converter bolts. it was making the noise while cranking. also for the love of all that is good. flush that poor cooling system!
1998 Piston Slap questions/New Piston Install panzerman200 OEM Tech Discussion 4 June 11th, 2016 23:26
Piston slap questions MoFo OEM Tech Discussion 5 November 27th, 2010 15:26
Piston Slap? xjh3 OEM Tech Discussion 29 September 29th, 2010 08:56
Piston Slap Question stephenspann27 OEM Tech Discussion 23 October 22nd, 2009 08:37
piston slap markaboo929 Modified Tech Discussion 6 February 27th, 2007 13:42
