Old July 17th, 2017, 12:40
WI-Jeeper's Avatar
WI-Jeeper WI-Jeeper is offline
WI-Jeeper's 2001 build thread
Hello , long-time lurker of these forums and decided I should finally sign up and contribute. Recently purchased a 2001 Sport 4x4 with 156k for $2k that I intend to build into something less boring than stock trim, but not too crazy because it will live mostly on the roads (more "overland", less "Moab").
This is one of many projects and money is somewhat limited so I expect progress to be slow. In the end my goal is to give back to the community where possible and show what a little reading on this forum can teach someone about our beloved XJs. I'm also pretty handy with computers and photos, and maybe I can add some writeups as time goes along.
Here are photos the day I brought her home (05/13/2017):
Driver rear fender flare fell off, ugly gray door bump strips, sad steel wheels:
Headliner falling down badly:
156k miles and spent the first 10 years in North Carolina. Not much rust, but also hasn't been taken care of 100% by the PO. Needs basic maintenance on everything.
Roof rust is about the worst of it, looks like it lived under trees. Otherwise for a Jeep in Wisconsin it has the cleanest floors & undercarriage I have seen.
Came with the OG window sticker so thats pretty cool!
Last edited by WI-Jeeper; July 17th, 2017 at 12:57. Reason: Getting links for the photos dialed in because vBulletin derps hard.
Old July 17th, 2017, 13:08
WI-Jeeper's Avatar
Re: WI-Jeeper's 2001 build thread
[06-24-2017] Because this isn't my daily driver, I took a few weeks just to joyride on weekends and shake down what needs fixing. The answer? Lots, but no cause for emergency. I knew what I was getting into, and this will be a long-term build.
First thing is the low-hanging fruit. And by low-hanging, I mean the headliner. I'm only 5'6" but this was driving me bananas. Pulled out the assembly, went to my local Jo-Ann Fabrics for material, and applied new fabric using Permatex 27828 Heavy Duty Headliner and Carpet Adhesive. CAUTION: If you have never done this before, go slow and DO NOT try to pick up & fold over large lengths of material - you will get wrinkles and possibly have to do this twice like I did!
Old saggy mess:
Getting cleaned up. Used a plastic scraper to remove bulk of material, then scrubbed with a nylon parts brush. Wiped down when complete with some acetone on clean Scott towels but that may be overkill.
All cleaned up for dinner:
Folded material halfway back on itself and sprayed adhesive. 3-4 minutes between coats. You will use a full 2 cans on this. I found it helped to put a plastic dropcloth between the folded fabric to help it slide when massaging into place.
Results before installation. Only one noticeable wrinkle near the rear speaker opening, but unless you look it's invisible.
After installation. Originally had grey material that matched perfect but botched it up. Went with black the 2nd try because thats all they had. I don't mind the two-tone look as much as I thought. Hey its a Jeep anyways, right?
Last edited by WI-Jeeper; July 17th, 2017 at 13:09. Reason: Fixing some words & formatting
Old July 17th, 2017, 13:17
WI-Jeeper's Avatar
[07-01-2017] Removed most of the door trim for a cleaner look, cleaning off the adhesive backing is a nightmare! A few weeks ago I was able to pick up a set of super clean Ravines and nearly new 235/75/15s off Craigslist (thanks Mandy). Finally got them mounted up, huge improvement for the appearance and gain a net 1" of lift! My rear leafs are flattened out all the way and now thinking about lift kits. Needs a full front suspension/steering rebuild too.
Old July 17th, 2017, 20:16
WI-Jeeper's Avatar
[07-16-2017] Audio system is in sad shape - bad speakers in the rear, broken wires for the fronts, and aftermarket radio was connected using the twist/tape/pray method. Soldered up the radio harness, swapped in Sony XS-R1645 6.5" speakers (Walmart special but they do the job), and spliced in new wires for the front doors.
Front speakers and wiring fix:
Waiting on a large RockAuto shipment to arrive for the next phase of maintenance & upgrades.
Old July 18th, 2017, 13:17
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
That's a great start. Pretty cool that you have the Moroney sticker also. Mine had the sticker with it when I bought mine. My sticker price was exactly $1000 more than yours. Mine has the 60th Anniversary package.
Dirk DeYoung--Member #176--National Vice President, SEC President
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2013 WKII (SUZIE)...2006 XK (TOW RIG)
Old July 18th, 2017, 17:39
WI-Jeeper's Avatar
Thank you! Yeah it was a nice surprise to find the Monroney sticker folded up in the glovebox. Congrats to you on pulling a 60th anniversary model, thats neat!
Old July 22nd, 2017, 12:58
WI-Jeeper's Avatar
[Originally from 07-08-17 but I'm slow] Went to the junkyard and pulled parts for cruise control and installed in my XJ in about 1 hour. Pretty simple and probably the best $25 I ever spent! (Credit to this thread for helpful info)
Old July 22nd, 2017, 16:04
WI-Jeeper's Avatar
Still tackling basic repairs. Existing muffler was rusted out and loud. Cut the OEM tailpipe from the muffler using a reciprocating saw. Cut one of the muffler studs with the saw, the other one had to get creative with a cut-off wheel on an angle grinder (NOTE: If you try this, be careful not to shoot sparks by the fuel tank!).
Replaced with new Walker SoundFX muffler and tailpipe ordered from RockAuto. Initially had some confusion thanks to beer/heat/stupidity but was cleared up in this thread
Parts list:
Walker 18959 muffler
Walker 55188 tail pipe (you will need to cut off the rear exhaust hanger if using the OE rubber mount)
Walker 35336 2.25" clamps (x2)
Walker 35750 rubber isolator
Needed 2 nuts for the muffler's pressed-in studs but I had spares laying around. You may need a trip to the auto parts/hardware store or a local exhaust shop. Sorry I don't have part numbers or thread info on this - if anyone does, let me know and I can add for people in the future. Or just buy an additional 2.25" clamp kit and use those nuts, they should be the same size.
Last edited by WI-Jeeper; July 22nd, 2017 at 16:14. Reason: More details about my nuts
My first XJ build 2001 Mcmour Midwest Chapter 7 March 17th, 2016 02:01
Time for a build thread... 2001 XJ anthrax323 Modified Tech Discussion 115 July 2nd, 2015 13:50
2001 xj build (I know nothing) gird123 Modified Tech Discussion 47 November 12th, 2012 10:47
Couehunter 2001 build thread coueshunter Arizona Chapter 11 July 12th, 2011 22:06
Another HSV Jeeper Build Minagera South East Chapter 9 March 7th, 2011 07:08
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
