Old June 24th, 2017, 13:38
Sean778's Avatar
Sean778 Sean778 is offline
'89 Renix AW4 damaged shift shaft
1989 Cherokee pioneer, 4.0l, AW4, Np242.
I foolishly damaged the shift shaft and the seal on my AW4 when I was attempting to remove the old N.S.S. I would like to find a replacement shifter shaft and seal, but what I don't know is if I have to find a donor Renix era jeep, or if I can use one from a later model AW4?
Does anyone know of a source for these parts besides the junkyard? So far the local pick and pull has not had any Cherokees on the lot when I have had a free weekend. I found a used AW4 on Kijiji out of town for $100, but it is from a '98. Any advice would be appreciated.
I also can't get the reverse lights to work since swapping to a new parts store NSS, but I have a suspicion that my problem is the connector. When I get the other parts I need and remove and reinstall the NSS, then I'll try to diagnose that issue. My motivation and free time for this project have been in short supply since my son was born in 2015. Thanks!
Sean
Have to shift manually shift Renix tranny -> Bad TCU ? blondejoncherokee OEM Tech Discussion 9 June 23rd, 2015 19:04
SYE Shift shaft Elcapitano Modified Tech Discussion 4 July 3rd, 2012 10:40
Shift Shaft issue XJ4JOE OEM Tech Discussion 0 January 22nd, 2011 15:41
would this slightly damaged axle shaft still work? skylinergtr OEM Tech Discussion 7 January 2nd, 2010 21:56
broke AW4 shift shaft....how 2 replace 95XJ Country OEM Tech Discussion 10 April 1st, 2006 17:29
