Old June 20th, 2017, 12:24
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
poor idle with AC on
usually at lights and stopping it idles poorly with the AC running.
im unfamiliar with this issue, what is straining the idle and why?
Old June 21st, 2017, 07:38
90xj06's Avatar
90xj06 90xj06 is offline
Re: poor idle with AC on
when the ac is on the pcm should command the iac to increase the idle. you might have a dirty iac or intake.
is your idle speed low?
Old June 21st, 2017, 10:52
old_man's Avatar
old_man old_man is offline
What are the idle speeds with and without the AC on?
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old June 25th, 2017, 00:50
when it occurs its starts to bog a little below 1000-700 probably, so yes low, but not consistant. IAC has been cleaned as of a few months ago while checking a different issue, jeep ran better after to. this one is just weird.
I havent had AC on much, but when its full out running and a hot day its more noticeable.
Old June 26th, 2017, 16:38
bump
Old June 27th, 2017, 06:46
90xj06's Avatar
does it also happen if just the fan is set to high with vent or heat?
Old June 27th, 2017, 08:06
old_man's Avatar
Normal idle should only be around 600-700 on a Renix even without the AC. The emissions police dinged me because mine was idling at 900 hot.
Loveland, Colorado
Old June 28th, 2017, 01:20
the idle almost stumbles when its on full, and it is not consistent,kinda random. i havent tried this on heat but i will tomorrow.
Old July 6th, 2017, 15:30
XJ 2.5 XJ 2.5 is offline
When your a/c is on, does the compressor spin constantly, or does it cycle on and off? Your a/c system could be undercharged.
Old July 6th, 2017, 18:46
Would undercharged cause the idle to spudder?
Old July 7th, 2017, 09:27
old_man's Avatar
It would cause a more constant load on the engine. If you are sputtering at idle, I would be thinking more spark plug wires, cap, or even plugs themselves.
Loveland, Colorado
Old July 7th, 2017, 09:49
dan1977p's Avatar
dan1977p dan1977p is offline
Though I think it's a tuneup issue, are your vents going from vent to defrost when the idle changes? You're expected idle is higher than normal and the first thing I check in that case is for a vacuum leak and that leak may be getting worse under load. That could cause your vents to mess up.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old July 7th, 2017, 16:15
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
I agree with these two!!! But year is it????
If it 1990 or older, Renix, the grounds may need cleaning badly!!!
Could be both!!!! Or all three, vacuum leaks, needs a tune up and grounds cleaned up
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old July 7th, 2017, 16:17
Ecomike's Avatar
NAXJA# 2091
The AC is just a distraction, unless the belts are squealing. That load just makes the wandering idle more noticable.
4.0 XJ correct idle is 750 rpm
Old July 7th, 2017, 20:30
It will dip below 750 when it's sounds like it's going to shut off. 600 or less maybe, then pick up shortly after. Once driving it's fine.
I need to replace the main grounds from the battery because of another issue. Could this hinder idle with AC on full?
Top 10 causes of a bad poor rough idle.... bimmerjeeper OEM Tech Discussion 7 November 26th, 2012 12:55
Intermittent poor idle on 00' XJ xjtrailrider OEM Tech Discussion 6 May 15th, 2010 19:30
bad idle and poor running CW OEM Tech Discussion 11 May 2nd, 2007 23:11
Low RPM stumble/poor idle blaisetd OEM Tech Discussion 31 August 28th, 2006 21:16
88 4.0l low/poor idle woody OEM Tech Discussion 3 January 5th, 2004 10:16
