Old June 4th, 2017, 12:54
indian's Avatar
indian indian is offline
XJ LM7 5.3 swap
I decided to start this thread because it can help someone. I got a lot of inspiration from other's threads like from racer32, John D, PhotoJared, Frank Z, Jeff 98XJ WI, etc.. I would like to thank all the XJ LS swapers. Excuse my english.
My XJ is a 2001 sport. I put a M62 supercharger in it to get more power, but I was not very satisfied. Then I put a comp cam 232-4, piggyback ecu, wideband, headers but the results was poor for the effort. So I decided to go the LS route because I knew the engine from Corvette and I very like the V8 sound and torque production.
Now I am at the middle of the swap. (I hope).
This swap began in Feb 2017 when I got the package from ebay:
then I pulled the old engine out:
which one is better?
but when I took the old truck intake I got a bad feeling about the LM7 (156k miles) engine
and my frustration was bigger and bigger
the engine was full of carbon buildups
so I continued to the bottom end and without any surprise it was full of rust and carbon
the rod bearings destroyed
Old June 4th, 2017, 13:09
indian's Avatar
Re: XJ LM7 5.3 swap
cleaning and rebuilding of the engine:
new exhaust valves
new valves seals
old springs, retainers cleaned
heads ready to instal
crank bearings left some marks on tha crankshaft
hope this will work
most engine parts ready
honing the cylinder
should be OK
assembling the bottom end
installing the oil temperature sensor for my VDO oil temp gauge
Jeep oil pressure sensor for the OEM jeep cluster
a little bit longer adapter for the Jeep coolant temp sensor
thanks Racer32 I bought the Camaro 99 headers
Old June 4th, 2017, 13:27
indian's Avatar
Re: XJ LM7 5.3 swap
for the fuel delivery I decided to use the sending unit from the diesel XJ (has inlet and outlet without regulator) and combined it with the 4.0 fuel pump. regulator is GM on the rails
I bought the russel fuel lines and adapters:
lowered the truck fuel rail crossover line
some clearance issues with throttle body and water pump outlet. slighty bended and looks OK
test fitting of the intake hose with MAF
other VDO oil temp sensor for the 4L60e
engine and tranny together again
swapping the input gear and planetery gear from the NV246 to the NV231
for the VSS I reused the 37 teeth ring from NV246 and placed it into the NV231. I will then reprogram the ECU to count the 37 teeth (stock VSS is 40 teeth ring)
the GM VSS sensor adapted into the NV231
many thanks Racer32 for the adapter ring specs
Old June 4th, 2017, 14:18
racer32's Avatar
racer32 racer32 is offline
Re: XJ LM7 5.3 swap
Wow Peter looks great so far! Glad the adapter worked for you. Looking forward to more
Old June 4th, 2017, 14:20
indian's Avatar
Re: XJ LM7 5.3 swap
end of May 2017 - LM7 first (hopefully last) install
transmission mount
engine mounts - I welded some universal LS mounts to the stock Jeep mounts
manifold to mount clearance - passanger side
manifold to mount clearance - driver side
Old June 4th, 2017, 17:23
cleenrob's Avatar
cleenrob cleenrob is offline
Re: XJ LM7 5.3 swap
yay for more lsxj's!
looks good
Old June 4th, 2017, 19:24
Serious Offroad's Avatar
Serious Offroad Serious Offroad is offline
NAXJA Supporting Vendor
Re: XJ LM7 5.3 swap
Looking good!
Old June 4th, 2017, 22:30
clydefrog's Avatar
clydefrog clydefrog is offline
Re: XJ LM7 5.3 swap
Nice! What color blue is your Jeep? Looks super cool. Also...I am a little jealous of your fuel line setup.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old June 4th, 2017, 22:45
indian's Avatar
Re: XJ LM7 5.3 swap
thanks guys!
clydefrog, the stock color was Patriot Blue Pearl but I repained it with raptor bedliner and mixed two blue RAL colors
Old June 4th, 2017, 23:47
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Re: XJ LM7 5.3 swap
I hope you replaced the knock sensors while you have the engine apart.
Apologies if I missed that.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old June 4th, 2017, 23:51
indian's Avatar
Re: XJ LM7 5.3 swap
nope, I reused the old ones. If they sucks I will then replace them. I will check them with HP tuners when tuning the ECU
Old June 5th, 2017, 23:38
indian's Avatar
Re: XJ LM7 5.3 swap
modified jeep throttle cable bracket:
very custom modified jeep transmission cable bracket
I only grind the last detent and it shifts through all the gear without any problems
transfer case shifter linkage (it will be welded and painted)
Old June 9th, 2017, 14:28
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
Re: XJ LM7 5.3 swap
Nice looking good!
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old June 9th, 2017, 18:12
trippled trippled is offline
Re: XJ LM7 5.3 swap
If you have a problem do the harness too! It is very problematic with corrosion.
You're in Slovakia? That's gotta make it fun to get parts! Good looking build so far tho.
Old June 9th, 2017, 23:50
indian's Avatar
Re: XJ LM7 5.3 swap
I checked the clearance between oil pan and front axle and I think I am very tight. the engine is too low. At full drop the steering stabilizer bolt hits the oil pan:
I made bigger bumpstops and cut the bolt:
oil pan to axle very tight at full drop:
other option is to buy a flat steel oil pan. or any other suggestions?
and with the parts to EU it is not a big problem except I have to wait longer and pay a import fees. yesterday I got a very nice package:
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 23:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 09:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 21:26
231 swap into a 89 xj with aw4 bcmaxx Modified Tech Discussion 6 October 17th, 2007 15:31
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 13:40
