Old May 18th, 2017, 19:25
Noah_LBZ Noah_LBZ is offline
1992 XJ motor swap
This topic may already be on here but I am not getting a for sure answer.
I have a 92 XJ sport with the 4.0 HO. (needs a motor very bad) I found one for sale (motor/tranny/transfer case) for $600 with 91k miles. That motor is out of a 90. from my understanding that is not a HO. Will it still work and be a fairly direct swap?
Thanks
Old May 19th, 2017, 18:05
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: 1992 XJ motor swap
HO or not HO, boils down to some very minor internal differences. Any 1990-2001 XJ Cherokee or 1993-98 ZJ Grand Cherokee 4.0 L engine block will interchange.
Remove and re-use ( or replace with new ) as needed or required from your original engine: Intake/Exhaust manifolds, throttle body, flex plate/flywheel, cylinder head, water pump, distributor-less ignition or distributor assembly, OBD engine computer sensors, fan belt driven accessories, and/or mounting brackets.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old May 25th, 2017, 07:22
cruiser54's Avatar
cruiser54 cruiser54 is offline
Yes, with some things to be done.
The link below is my write-up on how to go from a REnix to an HO.
Use it as a guide to do the opposite and you'll be fine.
http://cruiser54.com/?p=100
Old May 26th, 2017, 06:33
themauler's Avatar
themauler themauler is offline
1992 XJ motor swap
The price is good but these things are a dime a dozen. Why put yourself through all of that work when you could just drop one in and plug it all in?
ZJ 5.2 motor and iron man fab motor mounts - anyone on here want to do a v8 swap? blondejoncherokee Sierra Chapter For Sale 2 August 26th, 2016 10:34
np231 swap from 1998 aw4 to a 1992 ax15 wayne2300 OEM Tech Discussion 4 September 1st, 2010 15:33
1994 motor swap to 1998-2001 motor. NEED HELP! ADrgnmn OEM Tech Discussion 14 October 6th, 2008 01:05
Motor Swap question 1998 motor into 1991 bigbadwolf54 OEM Tech Discussion 2 January 3rd, 2007 22:32
Parting 1992 XJ has motor/2wd tranny smartazz19 For Sale: Private Party Only. XJ ITEMS ONLY 9 March 21st, 2005 09:57
