Old May 18th, 2017, 11:31
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
any clock spring?
99 xj auto With cruise. Reading on the forums ive gathered i need to find a clock spring that hosts cruise control option if i want to retain mine.
However what i would like to know is if there is any specific brand/specific replacement i should look for or will any match off amazon work?
Old May 18th, 2017, 12:03
N8N_99xj N8N_99xj is offline
Re: any clock spring?
Why not get a used one? >$100 for cruise ain't worth it. It won't even engage under 35 MPH making it worthless for school zones.
Old May 18th, 2017, 12:55
emx721 emx721 is offline
many including myself have used Dorman with success, plus it has a lifetime warranty
My Jeep 99, also had cruise but never used cruise, so I put on a clockspring with no cruise and saved about $50 on the part
Old May 18th, 2017, 13:01
dorman 525-118 without cruise or
DORMAN 525-109 with cruise
Old May 18th, 2017, 13:19
Great thanks guys, just wanted to make sure it's not a key stealership need replacement
Old May 18th, 2017, 14:38
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
I got lucky and grabbed mine at a JY for a few bucks. I will have to double check that I have the rotation centered before I install it.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Old May 20th, 2017, 18:46
how do you center a used clock spring?
Old May 20th, 2017, 20:13
If you buy the Dorman's they come pre-centered with a tab holding it in the correct position, and when you are done with the installation you pull out the tab from the clockspring before you put the streering wheel back on.
Make sure your front wheels are straight before you start the removal/install
from amazon review "you have to pull black plastic tab out after you have part on steering shaft and located..at top center is the plastic pull tab,,
you have to yank on it pretty hard to pull out..it is a locking retainer for spring until part is installed."
As far as a used one I saw a link at Jeepforums: http://www.jeepforum.com/forum/f11/9...2/#post9189097
ADJUSTMENTS
CLOCKSPRING CENTERING
If the rotating tape within the clockspring is not positioned properly in relation to the steering wheel and the front wheels, the clockspring may fail during use. The clockspring must be centered if it is not known to be properly positioned, or if the front wheels were moved from the straight-ahead position with the clockspring removed during any service procedure.
WARNING: THE AIRBAG SYSTEM IS A SENSITIVE, COMPLEX ELECTROMECHANICAL UNIT. BEFORE ATTEMPTING TO DIAGNOSE OR SERVICE ANY AIRBAG SYSTEM OR RELATED STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENTS YOU MUST FIRST DISCONNECT AND ISOLATE THE BATTERY NEGATIVE (GROUND) CABLE. THEN WAIT TEN MINUTES FOR THE SYSTEM CAPACITOR TO DISCHARGE BEFORE FURTHER SYSTEM SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE TO DO THIS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY.
(1) Turn the steering wheel until the front wheels are in the straight-ahead position before starting the centering procedure.
(2) Disconnect and isolate the battery negative cable. If the airbag has not been deployed, wait ten minutes for the system capacitor to discharge before further service.
(3) Remove the airbag module as described in this group.
(4) If the vehicle is equipped with the optional vehicle speed control, unplug the speed control switch wire harness connector in the steering wheel.
(5) Remove the nut that secures the steering wheel to the steering column upper shaft.
(6) Remove the steering wheel with a steering wheel puller (Special Tool C-3428B).
(7) Rotate the clockspring rotor clockwise to the end of its travel (Fig. 14). Do not apply excessive torque.
(8) From the end of the clockwise travel, rotate the rotor about two and one-half turns counterclockwise, until the rotor flats are horizontal. If the clockspring wire harness is not at the bottom, rotate another one-half turn.
(9) The front wheels should still be in the straightahead position. Install the steering wheel being certain to fit the flats on the hub of the steering wheel onto the formations on the inside of the clockspring. Pull the wire harness from the clockspring through the lower hole in the steering wheel hub. Tighten the steering wheel nut to 61 Nm (45 ft. lbs.). Be certain not to pinch any of the wiring between the steering wheel and the nut.
(10) Install the airbag module as described in this group
Old May 20th, 2017, 20:22
Bent's Avatar
Very carefully rotate it lock to lock counting the rotations. Back to center half of the turns. Center wheel as mentioned and install.
If pulling a used one from a JY center the wheel before removing, masking tape it when its out so it won't move. Sometimes you can't center the donor wheel with any certainty.
SoCal Chapter VP
Old May 21st, 2017, 00:41
Ralph77 Ralph77 is offline
I just installed cruise control in my '00 that did not come with it. Used all boneyard and Craigslist part out parts. I purchased 3 units because I kept on coming across them and got them cheap. 2 I pulled the whole steering column. One was just the necessary pieces. Like an idiot I did not realize at the time about steering wheels being straight and clock spring positioning. Had the parts for quite sometime and fortunately when I got around to the install realized my mistake. I have a 2001 Jeep Service Manual. A real one. They describe the clock spring centering procedure posted above. I did it and all seems OK. Started the Jeep from the passenger side. Airbag did not deploy, airbag light did go off, and the horn works. Turned the wheel lock to lock and took a road trip. Everything works as it should. I am guessing I would have a problem if I screwed up doing the re-centering procedure.
Old October 5th, 2017, 11:20
burntkat burntkat is offline
NAXJA Member #1145
I'm in a similar boat. Have a 97, I want to keep Cruise.
The part 525-109 is listed on Dorman's site as only being for Wranglers. Is this not correct?
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old October 6th, 2017, 11:43
Bent's Avatar
You may try cross checking schematics on a Chrysler direct parts supplier for OEM part numbers. If they are the same it should show up there.
SoCal Chapter VP
Old October 6th, 2017, 12:08
RCP Phx RCP Phx is offline
For the 97-01 with cruise control................https://www.morris4x4center.com/mopa...e-xj-2000-1094
know where to get a clock spring? FloydXJ Intermountain Chapter 7 September 15th, 2012 18:06
WTB: Clock spring, 97+ Fore Wheeler MWC For Sale/Wanted Forum 2 August 30th, 2011 11:57
wtb: clock spring Wiser SoCal For Sale 16 January 24th, 2011 22:18
97+ Clock Spring tazion23 Wanted: Private Party Only 0 February 12th, 2007 12:37
