Old April 30th, 2017, 17:54
1989AMCXJ 1989AMCXJ is offline
Ford Dura spark II conversion from Renix Ignition Module
Ok, so the Renix ignition system has a Ford Motorcraft distributer, and the coil type is similar to the MSD 5527 street fire, (and works well) I am NOT trying to re-invent the wheel or get more performance here...it's just that the replacement parts nowadays are total crap, and don't last...so I am trying to make a better ignition system that lasts...I read that the 70's and early 80's AMC Jeeps used a complete Ford ignition system using a duraspark ignition module. Has anyone here used this set up on a Renix Jeep? Oh and yes I am having heat soak issues with the Renix ignition module, which happens to be brand spankin' new.
ignition module offroadxj07 OEM Tech Discussion 6 May 29th, 2005 14:06
Ignition Module ? billygoat Wanted: Private Party Only 1 October 25th, 2004 11:00
Ignition control module/Ignition Coil '88 4.0l RTicUL8 Wanted: Private Party Only 5 October 24th, 2004 20:12
Ignition Module....... Ghost Wanted: Private Party Only 4 September 14th, 2003 21:07
