Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter
Colorado Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old April 25th, 2017, 11:16
SFXJ125 SFXJ125 is offline
Replaced ignition coil and on to exhaust
What's up gents? Was away at training for a couple months but back now.
Some updates and lots of questions for y'alls expertise. Went wheelin Hackett and lingwater couple weeks ago and had a great time with one minor issue. Jeep died at top of longwater. Popped hood and checked fuel, air, and spark. Fuel good and air filter looked good. She would crank but not turn over. Intermittent spark from coil. Got pulled to trailhead and she finally started when we got off Trail. Over heated I guess.
Took coil off last night and saw that the coil, probably 20 yo original had crack down its side. Replaced it and she starts now and seems to run better than before so that's good!
Also did Power Steering pump. Leaking out the reservoir and whining like a little you know what. Still whines a little bit I will flush again and see if that clears it up. Really didn't want to spend money on PSC pump but might go to that eventually. Could the 33" tires and stock steering be my whining issue?
Now it's on to my exhaust and torque converter. Will tighten up torque converter bolts as well as do exhaust. Couple questions before I do it though.
I'm thinking of going with the dorman oe exhaust over some performance headers with a walker downpipe, a magnaflow universal cat and a dynomax muffler/tail pipe. Anyone run this system? 2.25 or 2.5"? Honestly I've scoured the forum and it seems like stock was/is good and no real gain over increased pipe size after/before catalytic converter.
Also, what do y'all think about swapping 99+ intake while I'm at it since I'll be taking it off anyways?
After exhaust I'll be doing the steering (tie rod/drag link). Probably going to convert to 1.5" .25 wall 3/4" bunged heims. Thoughts?
After exhaust and steering I'll get around to a new paint job. I'm thinking P-40 with OD green top and blue/grey lower panels and underside. Some sharks teeth up front...
Old April 25th, 2017, 11:21
Re: Replaced ignition coil and on to exhaust
Also, forgot to mention. I'd like to become a member so who do I talk to about that?
Tax return burning a hole in my pocket...
Old April 25th, 2017, 11:24
Kittrell's Avatar
Kittrell Kittrell is offline
That part is easy.
http://www.naxja.org/forum/payments.php
Old April 25th, 2017, 11:49
Awesome, thx. Any swag with membership? Like a decal or something? I have a decal already on rear window but it's from previous owner.
Old April 25th, 2017, 12:06
Kittrell's Avatar
Yeah, membership will send you a new decal with your welcome letter.
Old April 25th, 2017, 12:30
Hypoid's Avatar
Hypoid Hypoid is offline
What year is your XJ?
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old April 25th, 2017, 12:51
It's an automatic 97.
Old April 25th, 2017, 13:37
smokeyyank's Avatar
smokeyyank smokeyyank is offline
33's on stock steering shouldn't be an issue. It may just be the pump going out. I honestly suggest a WJ/Durango upgrade. Cost me about $300 total to do mine and is one of the better upgrades I did.
As for exhaust just stick with stock size. I used a HF cat and Thrush muffler and had an exhaust shop fab the rest, wasn't that expensive and works fine.
Steering linkage just kind of depends, after researching I decided to just stick with stock setup and upgrade the TRE's and tie rod. Works for me but everyone ahs their opion on it.
99 intake is a good upgrade, and if you're taking it off might as well.
Old April 25th, 2017, 14:17
Kittrell's Avatar
I'll play devil's advocate and say to stay away from the Durango box as you lose steering radius. If you do some searching, more and more in recent year folks are just going with reman XJ boxes unless they are stepping up to a PSC unit. I have some fluid around my box and I can't yet pinpoint where it's from. But I will be on 35's and with just replace with a reman XJ box and new lines if I need to replace. Getting something like the Boostwerks brace would be money better spent.
http://www.boostwerksengineering.com...Brace_p_8.html
Old April 25th, 2017, 14:35
DutchVDub's Avatar
DutchVDub DutchVDub is offline
You won't lose steering radius with the Durango box, it still spins the sector shaft the same amount as the stock XJ Saginaw box. The only way you would lose turning radius is from running a shorter pitman arm on it. The Durango box has a larger piston, thus produces more steering force, and a faster lock to lock ratio.
Is it a huge difference mover stock? No, but it is a decent upgrade.
Americans can sleep at night because US Soldiers stand ready to fight
Old April 25th, 2017, 14:38
Kittrell's Avatar
Good read
http://www.naxja.org/forum/showthread.php?t=915103
Old April 25th, 2017, 14:55
DutchVDub's Avatar
New to me. I know people that run that box and neither of them have any issue with not hitting the steering stops on the axle. A little google-fu seems to point to using a WJ pitman arm as its the same drop as stock but a little longer. I can't verify that.
Old April 25th, 2017, 16:30
old_man's Avatar
old_man old_man is offline
When I rebuilt Durango boxes, I pulled out the spacer ring and machined the cap and got the turning radius back. Personally, I didn't like the faster ratio. It made it a bit twitchy on the highway. Adding a longer pitman arm would only make that worse and cut down on your turning force.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old April 25th, 2017, 17:58
smokeyyank's Avatar
I haven't run into any issues with my set up and turning radius is unchanged.
Old April 25th, 2017, 19:01
Serious Offroad's Avatar
Serious Offroad Serious Offroad is offline
NAXJA Supporting Vendor
Originally Posted by Kittrell View Post
That guy is a Douche-Nozzle....
Rate This Thread:
Replaced exhaust manifold, start engine and the RPM's go out of control! jeeperguy21 Modified Tech Discussion 21 January 3rd, 2009 08:24
No spark, replaced CPS, ECU, ASD relay... nothing getting to the coil RubiconXJ90 OEM Tech Discussion 12 June 5th, 2006 21:51
Can a direct fit Cat be replaced without removing any other of the exhaust parts ? 96 Cherokee OEM Tech Discussion 4 August 23rd, 2005 19:47
Ignition control module/Ignition Coil '88 4.0l RTicUL8 Wanted: Private Party Only 5 October 24th, 2004 20:12
has anyone replaced the ignition switch!? bigoltrux77 OEM Tech Discussion 4 March 18th, 2004 00:54
