Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Cherokee XJ (1984 - 2001) > Modified Tech Discussion > Paint and Bodywork forum
Paint and Bodywork forum Around here sheetmetal is optional but if you are going to do it, do it right.
Old March 18th, 2017, 20:59
montanaman's Avatar
montanaman montanaman is offline
Prepping new steel for welding and painting ...
Hi guys ... I don't know much about painting, so I thought I'd ask :
New steel usually comes with a gray coating, which I guess is there to prevent rust. Not sure what it is, but should it be painted? Or should I strip it off before painting?
If it needs to be stripped, how do you do it? Chemicals, flapper wheel, or some other method?
Thanks.
Old March 18th, 2017, 21:09
xCWolf's Avatar
xCWolf xCWolf is offline
Bring the Boom
Re: Prepping new steel for welding and painting ...
As far as I understand you can use aircraft paint thinner/stripper to get it off
Old March 19th, 2017, 08:04
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
What kind of steel, and for what kind of project ? Cold rolled steel, which includes sheet metal, should only need solvent cleaning and scuffing before primer. Hot rolled steel tube or steel plate will give the best results if the mill scale is ground or sandblasted off. Solvents will have no effect upon mill scale.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old March 19th, 2017, 11:07
montanaman's Avatar
Thanks for the replies. Yeah, the magic words were "mill scale." I didn't know it was called that. Its the dark gray stuff on plates of mild steel. It's just ordinary steel that I bought from the local steel provider (Pacific Steel). I bought it for various projects, but right now I'm making a little mounting plate for an in-line fuse for my alternator upgrade. Tons of videos on YouTube for removing it with hydrochloric (muriatic) acid, sand-blasting, etc.
Thanks!
Painting powdercoated steel rims? bcmaxx OEM Tech Discussion 1 June 15th, 2010 10:51
painting steel wheels. few Q's -88fleXJ- Paint and Bodywork forum 4 April 13th, 2009 16:56
Painting OEM steel wheels Black... SurfXJSnow OEM Tech Discussion 19 August 2nd, 2007 13:32
Welding steel castings falcon556 Modified Tech Discussion 15 December 10th, 2006 14:24
Welding to spring steel? Lucas Modified Tech Discussion 17 July 17th, 2004 21:35
