Old March 11th, 2017, 10:24
jeeptec's Avatar
jeeptec jeeptec is offline
1 ton steering
Ok I'm getting ready to my 1 ton utk steering upgrade. Right now I have a Synergy suspension track bar that has a pretty good drop. From the frame mounting edge to the track bar center bolt is 6 inches. Plus I have there drop pitman arm. Which is about 3/4 to 1 inch lower than stock. Well taking apart the 92 parts Cherokee I have turns out it has an Iron rock Offroad track bar and bracket. It measures from the frame mounting point to track bar mounting bolt 5 1/4 inches and uses the stock pitman arm. Which one do I use?
Old March 11th, 2017, 14:13
clean4drxj's Avatar
clean4drxj clean4drxj is offline
1 ton steering
How much lift? Generally speaking it's better to have a flat draglink setup than high angled one.
Old March 11th, 2017, 15:19
jeeptec's Avatar
1 ton steering
Almost 5 inches.
Old March 14th, 2017, 01:31
StinkyFab's Avatar
StinkyFab StinkyFab is offline
NAXJA Supporting Vendor
Re: 1 ton steering
you want your drag link and track bar to match angles as closely as possible. If your track bar drop and pitman arm drop line everything up, then great. Here's a little tutorial on what you should be looking for.
Dallas Ashley
WWW.STINKYFAB.COM
Motor Mounts, Fabrication tools, and Custom stuff for your Jeep!
Steering Issue - choppy steering wheel return fishinpolejoe OEM Tech Discussion 10 July 2nd, 2015 13:09
Steering Shaft Brace? Looking for ideas for my steering problem. andrew2516 Modified Tech Discussion 37 March 12th, 2013 09:48
WTB+FS - WTB HD Steering +HD trackbar-FS Rudged Ridge steering element96x NAC Classifieds 0 October 11th, 2010 23:00
89 XJ Steering Gear Box, PS Pump, and Steering Shaft For Sale waxer SoCal For Sale 4 June 22nd, 2008 13:34
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 13:38
