Old March 4th, 2017, 15:48
cletus141 cletus141 is offline
Mods, please delete this thread
I'm baffled. Fuel pressure holds at about 32psi, but will slowly bleed down to about 28 after 5 mins. I checked spark to all 6 cylinders and it's there. I originally checked 1 cylinder and wasn't getting spark, then read something about unplugging the CPS for 5 minutes, re-plugging, and trying again. Now spark to all 6. So maybe I didn't check it correctly the first time.
Timing issue?
Old March 4th, 2017, 16:07
Re: I'm baffled. Getting spark AND fuel, but cranks and no start
I've also sprayed Starting Fluid into the intake and no fire up
Old March 4th, 2017, 16:25
ok. I googled "spark and fuel, no start" and read something on Cherokee forum about it being flooded and try starting at WOT. So, I cranked and cranked at WOT and it eventually started. Being flooded made sense since I'd been cranking all morning checking fuel pressure and spark.
Old March 4th, 2017, 16:31
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
So it Is running now?
Old March 4th, 2017, 16:36
yes. I posted in the other thread and I've asked a Mod to delete this thread. Can you check out my questions in there?
Has spark, has fuel, cranks but wont start...I'm desperate nicpaige OEM Tech Discussion 41 March 12th, 2016 17:48
it cranks, has fuel, no spark Eagle02 OEM Tech Discussion 13 March 23rd, 2009 18:06
'91 4.0 cranks but no start has fuel and spark Avanteone OEM Tech Discussion 8 January 28th, 2009 04:45
Have Spark, Have Gas, Cranks, No Start Powderhound OEM Tech Discussion 32 December 18th, 2007 10:57
Cranks, No Start. Have spark & fuel. DonkRado OEM Tech Discussion 9 December 3rd, 2006 12:59
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
