Old March 4th, 2017, 08:59
Sullie Sullie is offline
Arrow #7 fuse on 1984-9188 AMC style fuse panal
I own a 1988 XJ, I am going to put the symptoms of my Jeep in bullet format and hopefully someone can help me.
o when i turn the key over the 10 AMP fuse for the #7 (Parking lamps,
Headlight warning chime/ buzzer, instrument panel light dimmer) keeps
blowing
o no parking lights or brake-lights when key is on and brake is depressed
o left turn signal works intermittently, right works regularly.
Here is a picture of the highlighted fuse i am referring too
Here is a picture of my fuse box
Old March 4th, 2017, 10:28
Re: #7 fuse on 1984-9188 AMC style fuse panal
I just noticed that the previous owner on the, #6 fuse (Brakes/ Hazards) has a 30 AMP fuse in it when it calls for a 15 AMP. Im going to replace this with the right size fuse, but would that cause the #7 fuse to blow?
Old March 4th, 2017, 11:51
Hypoid's Avatar
Hypoid Hypoid is offline
Do you have wiring diagrams for your Jeep?
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old March 4th, 2017, 12:26
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
That fuse shouldn't blow the other fuse. But it would be good to put it back to standard.
Is your jeep standard or automatic ? This problem reminds me of my 85 fuse box ruined by years of a leaking clutch master.
For the brake lights check the switch on the pedal those switches like to melt the plug. Most of the early xj I see have those plug wires cut and spliced.
What's the radio wiring look like? Had someone mix up the ground and it would blow the interior and dash fuse.
Old March 4th, 2017, 13:34
So i spent all afternoon tracing wires to ignition to the break lights.
This connection going from the fuse box to the ignition switch has power go from the 3 wire side (Black/ yellow wire), tracing wire further down it goes to the brake light switch with the (blue/ yellow wire).
[IMG][/IMG]
the (blue/yellow wire has no power going to it.
[IMG][/IMG]
further more everytime i depress the turn my lights on the #7 fuse blows and i tried to jump the power wire to the brake light switch and it kept blowing my #13 fuse.
yes i have a manual transmission
1988 jeep Cherokee xj
PLEASE HELP
Old March 4th, 2017, 13:42
Jeep Driver Jeep Driver is offline
Your brake light switch is fried.
Your running lights sockets are likely corroded.
Wiring may be chaffed.
Grounds are bad.
You still have your C101 which needs to be eliminated.
Your connectors are corroded..............headlight harness right behind front headlight.
There is no shop manuals shared here but they are given out like candy on other forums, look around.
Sorry, but you are going to have to go through your wiring, it's a mess.
I too have the 88...........you're just going to have to dig in.
Old March 4th, 2017, 13:54
I just don't understand how I can be getting power from fuse to connection , but not from connection to brake switch. My switch is good, did a continuity test on it and it passed
Old March 4th, 2017, 14:17
Ok, I dont know what i did but the breaklights are now working, however now the turn signals and reverse lights arnt working lol, talk about chasing grimlins.
Old March 4th, 2017, 14:21
I have the electric troubleshooting guides, might even cover this year but I'm out of town working for the next week so my library of books are out of reach.
Honestly I think you've got damage to your fuse box from leaking fluids, but more than that there is something shorting out the park lights,
brake lights I'd think Is in the switch or plug.
I start by looking at the headlight harness and tail light harness, seems like something is corroded or frayed.
Nothing should cause the ignition to on to overload the park lamps on its own. Something has to be powering on too or be making a connection.
When my radio was wired wrong the radio would blow the instrument lights when the head lights were turned on. My problem was one of the previous owners cut the plug and wired it by hand, guy I bought it from tried to help out by putting my radio in and got a ground wrong.
Check the headlight switch too those like to melt in the right conditions. But shouldn't be dependent on the ignition switch being on.
I have no clue about the c101 plug these jeeps have but they cause all kinds of problems, just follow the knowledgeable advice on that one.
It's going to be a pain to sort. Might keep it in the back of your mind to look out for a dash harness and maybe headlight harness for your year just in case trouble shooting doesn't work out. I've found it easier to scrap the old failing electrics and install good condition harness over trying to recondition it. My case was extreme from decades of previous owners cutting n' splicing and leaking fluid.
Old March 4th, 2017, 15:30
Reverse lights are a switch on the passengers side of the transmission. Not sure what route it take through the jeep. Were they working before?
When my fuse box was screwed I'd swap the flasher relay things around and some times get the turn signals working. Do the hazards work?
Old March 5th, 2017, 19:48
does anyone have a picture of the reverse light switch thats on the transmission, i got all the lights working except the reverse which, i will look at the reverse light switch( is there a continuity test i can do on that to make sure shes ok, if so how?) and the rear service lights.
correct me if im wrong but the rear red service lights should come on when i turn on my head lights, i looked at my headllight switch, she looks ok, is there a test to make sure?
Old March 5th, 2017, 20:03
If you have the 4.0 you'll have Peugeot ba10, that switch will be on the drivers side two wire plug probably . If it the 2.5 it'll be the ax5 and that's plug on the passenger side with two wire plug
If you have a fuse labeled transmission it may be for the reverse lights.
The rear lights are on a harness the plugs in behind the quarter panel, those plugs can become surprisingly messed up.
Old March 6th, 2017, 06:09
I have the straight 6, manual transmission. Im going to find it and do the paperclip bridge test today.
Old March 6th, 2017, 11:03
90xj06's Avatar
90xj06 90xj06 is offline
also from the picture your missing the chime module
Old March 6th, 2017, 11:31
so i got under the jeep today to look for the brake-light switch which i was told was on the drivers side since i have a straight 6 4.0L, right?
here is a picture of what i found, is this it? i was told it was a two wire connection, the only connection that is close is a 4 wire connection that leads to this...
98 Classic keeps blowing IOD fuse. Since fuse has blown better mpg? dcampbell98XJ OEM Tech Discussion 1 June 4th, 2015 15:39
How To Replace Brass Fuse Connectors in Fuse Block CJR OEM Tech Discussion 1 October 28th, 2014 14:24
how to bypass blower motor fuse in fuse block?? thatredcherokee OEM Tech Discussion 8 July 28th, 2014 05:33
Need wiring diagram for passenger fuse box, fuse #11(run/start ignition) johnsoninc86 OEM Tech Discussion 2 November 9th, 2009 14:56
Radio/Dome Light fuse Fuse Lowrange2 OEM Tech Discussion 14 November 29th, 2007 18:57
