Old March 2nd, 2017, 06:17
Sullie Sullie is offline
Arrow Warning indicators, brake lights
I have an 88 xj, when you turn the key over to accessory there are no warning light indicators that come one, furthermore she turns over and runs just fine.
Additionally when you depress the break the brake lights dont turn on.
Before someone ask I did the obvious and checked and replaced the fuses. Is there some other issue that is common that could be causing my issue.
Old March 2nd, 2017, 07:21
Hypoid's Avatar
Hypoid Hypoid is offline
Re: Warning indicators, brake lights
Could be two different problems. For the dash indicators, I would start with the ignition switch.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old March 2nd, 2017, 07:24
The ignition switch works, vehicle turns over and starts. Unless there's something not making contact within the internal working of it.
Old March 2nd, 2017, 07:42
Hypoid's Avatar
Exactly.
Keep in mind, this is a 29-year-old vehicle. Do yo have a working DVOM?
Old March 2nd, 2017, 08:25
DVOM?
Old March 2nd, 2017, 08:30
Hypoid's Avatar
Digital Volt-Ohm Meter, like the one on the right:
Old March 2nd, 2017, 10:45
Yes I have a multi- meter
Old March 2nd, 2017, 11:34
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
If the truck is a manual transmission, I have had issues with the terminals in the fuse panel being contaminated with brake fluid from a leaking clutch master. It killed my turn signals, brake lamps and heater blower. I ended up bypassing the fuse panel and installing inline fuses in all affected circuits. Plus repairng the leaking master and slave cylinders.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old March 2nd, 2017, 12:05
Thanks it is a manuel transmissio ,I'll check that out.
Old March 2nd, 2017, 13:21
90xj06's Avatar
90xj06 90xj06 is offline
by accessory do you mean turning the key backwards? also what dash lights are you referring to? an 88 xj would only have a seat belt light that would illuminate when you first turn the key on.
Old March 2nd, 2017, 17:10
four_shot's Avatar
How 'bout it Gonzo
I found that twisting the ends of the fuses a few degrees helps tighten the connection for a temporary fix.
4shot
no brake lights, turn signals or dash lights bmxdude151 OEM Tech Discussion 6 September 9th, 2013 07:51
No marker lights, no brake lights, no dash lights twodoorXJ OEM Tech Discussion 5 December 16th, 2012 08:35
Brake lights work but dont when tail lights are on ptf18 OEM Tech Discussion 4 January 14th, 2010 17:05
No reverse lights or brake lights or turn signals... TheHighHeat OEM Tech Discussion 6 October 5th, 2008 15:13
Warning to all with factory driving lights tchase OEM Tech Discussion 6 April 29th, 2005 21:22
