Old March 1st, 2017, 12:59
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
AC Suction/Discharge line leak?
98XJ - looks like I'm leaking on the line where it goes into the condenser? Is there a gasket there? Or is it a tapered pressure held connection?
Old March 1st, 2017, 13:25
md21722 md21722 is offline
Re: AC Suction/Discharge line leak?
There are a couple of refrigerant o-rings. The joint is held together with a garter spring.
Old March 1st, 2017, 13:51
Kejtar's Avatar
PostMaster General
I have fresh oil there so it looks like it's leaking from the damn joint... ugh.... AC was fully rebuilt 2 years ago with barely any miles on it...
Old March 1st, 2017, 15:12
Since Jeep discontinued the condenser the aftermarket ones are pure junk. When I replaced mine I had to get 3 different ones before I found one that would even fit at all. One I got to barely connect but could not get it apart, ended up taking a cutoff wheel and sending it back and trying a 2 more times before I got one that worked. Too much Chinese crap out there. Its helpful to pull vacuum & also pressure test with dry nitrogen and make sure both hold before thinking about adding refrigerant. In some cases the systems will hold pressure but not vacuum and vice versa, vacuum but not pressure. That's why I test both ways.
Jeep Cherokee A/C suction and discharge valves??? simspace OEM Tech Discussion 8 November 29th, 2015 16:22
Tranny line leak Burchie OEM Tech Discussion 12 March 25th, 2010 18:49
Brake line...what to do about leak? Muddy Beast OEM Tech Discussion 4 May 25th, 2009 08:13
Vacuum Line Leak TekkaMaki OEM Tech Discussion 3 April 20th, 2008 20:25
trans line leak jp904x4 OEM Tech Discussion 8 February 12th, 2007 20:53
