Old March 1st, 2017, 07:04
ehall's Avatar
ehall ehall is offline
prop valve leak at front bleeder
I was screwing around with the prop valve spring (rear disc swap) and now the distribution block is leaking from the front. Fixed it with a new o-ring. Is the screw supposed to be tapered? Doesn't look it. Looks like the o-ring is the primary stopper for the fluid. Doesn't seem right...
my '91 beater rebuild
Old March 4th, 2017, 17:32
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: prop valve leak at front bleeder
My 87 Renix is not tapered. The O'ring is the seal.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
broken bleeder valve shaman1204 OEM Tech Discussion 3 April 5th, 2013 16:05
BA/10 hydralic clutch bleeder valve Matt S. Wanted: Private Party Only 5 February 16th, 2007 17:26
Odd sized bleeder valve on front caliper. Markos OEM Tech Discussion 4 December 18th, 2006 06:56
great.. rounded off bleeder valve sjbond67 OEM Tech Discussion 9 September 5th, 2006 18:45
bleeder valve trouble NCSUcherokee OEM Tech Discussion 2 June 25th, 2004 17:00
