Old February 25th, 2017, 18:06
BALTANAKT BALTANAKT is offline
Want to tilt the seat base back
Hey all,
My prior XJ's all had the captains seats where the seat itself actually tilted forwards & backwards. I loved tilting it back as it sort of held you in the seat a bit - like bucket seats.
The XJ I have now has the basic seats which do not tilt, and I find them rather uncomfortable in comparison.
I was wondering if anyone ever modified the base for a more permanent tilt?
Old February 25th, 2017, 18:16
Saudade's Avatar
Saudade Saudade is offline
Re: Want to tilt the seat base back
You could stack a bunch of washers under the front 2 bolts to tilt it back a bit. Adjust the number of washers to get the tilt you want. If you stack enough, you might need longer bolts.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 200K
Old February 25th, 2017, 21:17
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
It's EZ to swap the "rocker" seat bases from XJ to XJ. Junkyard is your friend. They bolt right up! 4 bolts with their own trim.
1990 XJ - 4.0L AW4 It's white.
1988 MJ - 4.0L AW4 It's green.
Old February 25th, 2017, 22:56
alexgalexg's Avatar
alexgalexg alexgalexg is offline
In 84 AMC put some seats that swiveled at the base giving you the option of a bench like seat or a cradling bucket style seat or anything in between. May be worth your time to see if those still bolt in with the holes for later model Xj's. Think thats a safer option than washers because you need all that thread and bolt in the floor in case of an accident
Old February 26th, 2017, 12:02
BCKNBLK's Avatar
BCKNBLK BCKNBLK is offline
Add spacers under the front legs/feet to raise the front, and under the rears to raise the back. Simple.
Old February 26th, 2017, 12:49
Hypoid's Avatar
Hypoid Hypoid is offline
I have seen a few of those tilt bases in the yards around Denver. Although, I don't know if that does the OP any good. There is a lot of "Colorado" that is nowhere close to the Denver-metro area.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old February 26th, 2017, 19:35
Ooooh, which yards? I'm in Boulder. Would be worth it to drive out if I can simply swap the bases.
Thanks a lot fellas.
Old February 27th, 2017, 12:15
Hypoid's Avatar
BOULDER!!!!!!!!! The Denver U-Pull might be 20 minutes away from you. The Denver LKQ is 5 minutes away from there.
I have not been to the yards for a couple weeks, so I'm not sure what is there at this moment. Keep tabs on the "Junkyard Finds" thread in the Colorado Chapter. I have been known to give people a heads-up when I see something they are looking for.
Old March 1st, 2017, 19:23
Yea! Thanks man!
Master craft Nomad Seat (1) 200$ - with XJ adapter and a XJ seat base blondejoncherokee Sierra Chapter For Sale 0 January 29th, 2015 12:30
How to tilt axle back..Help please, the snow is coming. Bjorn86 OEM Tech Discussion 24 May 3rd, 2012 11:38
Need Headrest on back Seat, what seat back will swap easiest sleestack Modified Tech Discussion 15 March 27th, 2010 19:05
WTB: 97+ 2 door drivers seat tilt mechanism shelbyluvv Wanted: Private Party Only 2 April 18th, 2009 10:58
96-01 Power seat base red_01_xj For Sale: Private Party Only. XJ ITEMS ONLY 1 October 18th, 2007 07:48
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
