Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Midwest Chapter
Midwest Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old February 12th, 2017, 10:01
Reddout Reddout is offline
Center console fitment
I'm looking at a automatic '96 2-door XJ and the center console is a little beat up. Will a console out of a newer, say a '98 with the cup holders swap over easily?
Thanks
Old February 12th, 2017, 10:50
XJ&CHZ4ME's Avatar
XJ&CHZ4ME XJ&CHZ4ME is offline
Re: Center console fitment
Yes, but you will have a gap up under the dash. Perfect place to fit a slim cb .
Old February 12th, 2017, 11:27
Thanks
Old February 12th, 2017, 14:15
podm98c's Avatar
podm98c podm98c is offline
Also you are going to need the ebrake and the mount as well
Old February 12th, 2017, 20:22
IllianaXJ's Avatar
IllianaXJ IllianaXJ is offline
Support Your Local Trails
Yes, grab the mount to the trans tunnel. Self-tappers will work just fine. Grab the heater duct also. Ebrake will take some doing, I haven't done mine yet, 2 years later...
MWC Vice President
1995 XJ Sport Mallcrawler build
2000 GMC Yukon XL 2500 6.0/4L80e
Old February 12th, 2017, 23:00
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
I swapped a late model console in my renix XJ. All I did was bend the factory park brake lever over enough to to completely disengage it. I do have a late model lever to use, but haven't got around to it, since my park brake is no longer hooked up.
I will do that all again when I finish rear disc swap.
I also still have factory 4WD shifter in place.
I did install late model trans shift lever, which is plug n pray.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old February 13th, 2017, 02:48
Thanks
Rate This Thread:
center console jd4x426 Modified Tech Discussion 1 June 22nd, 2009 17:19
XJ center console gizmo327 Modified Tech Discussion 7 December 29th, 2006 12:16
console fitment ? KY-XJ OEM Tech Discussion 4 September 26th, 2005 16:21
