Old February 9th, 2017, 18:10
1-tonxj 1-tonxj is offline
Front rail plating thickness question
I decided to go ahead and plate the bottom of the front rails and was thinking 1/8th should be enough added steel I used that mostly because it is easy to make a ghetto brake and form it to rail shape .XJ is on built tons 44's full hydro linked caged ect and that is why I figured I would plate more than the usual production set of stiffeners allow . I can easily make a second set and plate over them.for a 1/4 plate thickness , but if the consensus is .125 is adequate no sense in addi.g more weight
frame rail plating Gunter Colorado Chapter 42 March 31st, 2013 15:06
front uniframe plating woody JeepSpeed, Prerunner and Competition Tech Forum 11 August 21st, 2009 11:51
A/B pillar trim, frame rail thickness? kastein OEM Tech Discussion 2 August 18th, 2009 11:13
Pre-runner style frame rail plating (forward of LCA mounts) jdbwrx Modified Tech Discussion 4 November 30th, 2007 15:56
Steering Box frame rail plating Gravesdiggerxj Modified Tech Discussion 13 June 18th, 2007 11:39
