Old February 5th, 2017, 11:37
96Sportxj 96Sportxj is offline
Reducing wind noise with weather stripping
Working on reducing wind noise and so far it is helping and the cab is quieter. However, the majority of the noise seems to be coming around the front triangle window now. Has anyone had success with replacing the weather stripping there or doing anything else to quiet it down?
-I put 3/8" weather stripping around the windshield under the stock stripping.
-Door gaskets are in good shape I would say they are 8/10
-My stereo is loud enough (must be getting old)
-Yes I know it is an XJ..
-Road noise is fine for now, I want to rid her of the wind noise coming in around the doors/windows.
9/16" weather stripping from home depot: Door shuts nice and tight now.
This seems to be the problem area, or at least the loudest area.
Old February 6th, 2017, 13:50
Re: Reducing wind noise with weather stripping
Downloaded a noise meter for the phone so I can get a better base.
Does anyone have experience with the window deflectors? They look like they would keep noise down around the tops of the windows.
Old February 6th, 2017, 14:28
90xj06's Avatar
90xj06 90xj06 is offline
looks like something to try. im working on keeping the water out of mine. all my window seals are dry rotted.
Old February 6th, 2017, 14:51
dan1977p's Avatar
dan1977p dan1977p is online now
My experience with those rain deflectors was that they created more noise when the windows were closed and less when they were just cracked. They only seemed useful to me when it was raining sideways and I needed to have the windows cracked running the defroster in summer.
Are your doors aligned well? Any gap there will cause a ton of noise. My windshield outer trim was also loose so I ended up pulling it and threw some duct tape on the gap until I can find a better solution and it dropped my wind noise down tenfold.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old February 6th, 2017, 16:16
Vernicious Vernicious is offline
The outer trim of my windshield started coming off on a road trip. The last 100 miles sounded like I was flying a helicopter. I ended up using 2 part aircraft epoxy on it to hold it down. The drive home was much quieter. I figured it was good enough for supersonic aircraft, it should be good enough for my subsonic XJ.
Old February 6th, 2017, 18:05
dan1977p's Avatar
That was my thought as well, but I didn't want to piss off the next guy who needed to replace my windshield.
SeXJ Build Thread
Old February 7th, 2017, 06:33
I peeled up the windshield trim pushed in 3/8" weather stripping and then put the trim back.
According to my phone decible meter:
+/- 5db
idling: 65db
65mph: 71db
onramp: 78db
Going to weather strip the rest of the doors and see if anything changes.
Old February 7th, 2017, 06:40
dan1977p's Avatar
I just went through the weatherstripping process and it didn't help on two of my doors because their lower hinge pins are broken so the door hangs too low. That's why I say you should check the alignment of your doors first and fix that before wasting time with new weatherstripping.
SeXJ Build Thread
Old February 7th, 2017, 08:10
CorneliusRox's Avatar
CorneliusRox CorneliusRox is offline
+/- 5db
idling: 65db
65mph: 71db
onramp: 78db
I wish you had the starting dB readings!
Also, you should see if you can get a dBA reading (the A weighs it for human hearing as opposed to all frequencies)
Old February 8th, 2017, 12:27
I will check them again but i think they are good. This was my moms daily driver since '99 and rarely drove on dirt.
Old February 8th, 2017, 17:26
ehall's Avatar
ehall ehall is offline
ZJ weatherstripping is thicker, all over the junkyards, easy cheap upgrade
my '91 beater rebuild
Old February 9th, 2017, 02:57
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
Is it longer than a xj weatherstrip? Did you need to trim at all?
Old February 9th, 2017, 06:14
ehall's Avatar
I don't remember. Easy to cut with tin snips though
Old February 11th, 2017, 16:23
Bobbie's Avatar
Bobbie Bobbie is offline
It's a jeep and it will have wind noise so the lifters don"t sound so loud.You could turn the radio up and keep the windows down.
Old March 2nd, 2017, 09:46
Finally drove the Accord and the cabin noise is 62-66db's with it floored going up a hill.
weather stripping Bdiddy11 OEM Tech Discussion 6 April 20th, 2012 10:00
Rear Weather Stripping scott00tj OEM Tech Discussion 1 December 26th, 2010 09:57
weather stripping AaronJXJ OEM Tech Discussion 8 April 23rd, 2008 12:19
Wind noise from passengerside- weather strip? blackhawk411 OEM Tech Discussion 16 April 1st, 2008 12:31
97 in need of weather stripping - onebluemcm OEM Tech Discussion 3 June 1st, 2006 15:22
