Old February 3rd, 2017, 14:11
GoBig06 GoBig06 is offline
Cali smog test woes...
So I'm required by law in the state of california to get my Cherokee smogged every two years. I went in to get it smogged today and these are the results.... http://imgur.com/a/Jup8o Saddest of sad days. My XJ has been deemed a gross polluter... It looks like my HC and NO are high. What do I need to do to fix this? O2 sensor? New catalytic converter? Also it's a 1999 4.0L with 33x10.5 tires with 4.56 gearing if that matters. My ODB reader comes out clean.
Old February 3rd, 2017, 14:38
xCWolf's Avatar
xCWolf xCWolf is offline
Bring the Boom
Re: Cali smog test woes...
lol I like that everything passes so It's running as it's supposed to but they didn't design it for cali in 2017 so sucks to be you.
But as far as helpful input I'm pretty much useless here.
Good luck!
Old February 3rd, 2017, 14:39
96Sportxj 96Sportxj is offline
A lot of good info in here.
http://www.naxja.org/forum/showthread.php?t=1077191
Old February 3rd, 2017, 14:41
You might also buy a 10$ OBDii scanner that connects to your android cellphone and see if any codes are coming up.
Old February 3rd, 2017, 14:44
Yeah I got a scanner already. No codes are coming up.
Old February 3rd, 2017, 14:50
So reading up on some of the other threads it looks like HC is from unburned fuel or running too rich. Can running too rich ruin the catalytic converter? Wonder if the burning too rich ruined the cat and lead to super high NO... Should I start investigating on how to fix the HC first?
Old February 3rd, 2017, 15:44
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Yes, running too rich can shorten the life of the cat.
Are all your tune-up parts are fresh, including the coil ?
Get a scanner or an App that shows live PCM data. Determine what specifically beside NO and HC is out of normal ranges.
Probably +60% of Jeep 4.0 exhaust manifolds are cracked. A cracked manifold allows the exhaust to suck clean air, fooling the PCM to think the engine is running lean. The PCM will richen the mixture to compensate for what it "sees".
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old February 3rd, 2017, 16:19
t-bone t-bone is offline
BTDT... The OBD2 systems know all; if it's not throwing a code, then your cat is likely just worn out, or is a non-ca spec aftermarket replacement. Are you much over 150k miles? My 1995 ford ranger had very very similar results at 196k, the tech at the smog shop noticed the cat was some non-CA legal aftermarket replacement. I got a CA legal cat put on and the NO and HC levels dropped to less than the "average" value for both. I was shocked at the difference it made.
My 98 xj just passed CA smog yesterday (2/2/17) It has over 250K and the cat has been replaced at least once that I know of. My HC is 23 @15mph, 12 @25mph; NO 146 and 166 respectively.
Hope that helps
Old February 3rd, 2017, 16:48
Yea I replaced the ignition coil in the summer.
I have an OBD scanner. Its pretty cheap though. Do more expensive ones have PCM data?
I'll do some googling to see how to check for cracks in a manifold. Thanks
Old February 3rd, 2017, 16:50
Hope that helps
I'm at 150k. It looks like the previous owner put a new cat on but I'll check to see if its a cali cat. I might just throw a new one and get a new O2 sensor and try a no pass no pay smog place.
Old February 3rd, 2017, 17:07
Might not be related to the problem but just recently in the past few days its been taking awhile to crank over when the engine is cold but starts up right away when warm. I replaced the battery back in September.
Old February 3rd, 2017, 18:05
I got the walker non-ca cat from ebay for 100$ shipped. From reading it looks like it is the same as the ca-legal cat they sell but doesn't have the epa stamp.
http://www.naxja.org/forum/showthread.php?t=1136959
Old February 4th, 2017, 07:53
Tim_MN's Avatar
The cracks are almost always at a weld joint, and usually have reddish dust visible. Using SeaFoam in the intake produces huge clouds of white smoke from the exhaust, some smoke will usually be evident at the cracks.
Old February 5th, 2017, 12:13
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
You should use an ohm meter to test the resistance of two hot sensors, the CTS and IAT, both temp sensors. They can affect cold/hot starts. Also you need to test the fuel pressure. If it is low it can cause the engine to run lean and cause high NOx.
You HCs are just barely over the limits. Your NOx is way high, indicating a bad CAT and or lean conditions in the engine. So focus on the NOx problem.
You can test the O2 sensor with an analog Volt meter, live. See my old thread here on O2 sensor testing. But for now I assume the O2 sensor is not the issue, and get a new CAT (see if it must be CAlif-EPA stamped to pass first!!!) first. Then see where you are.
And test the CTS and IAT sensors. The IAT sensor can get dirty and cause some issues, just clean it with soap and water or gasoline..... if it passes the ohm meter test. The FSM and many old threads here list the factory spec for the CTS and IAT resistance (ohms) at various temperatures.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old March 2nd, 2017, 09:49
Well did you figure it out?!
`98 SMOG Woes... xcm SoCal Chapter 17 April 4th, 2013 15:50
Need smog help! (Cali) H8D-XJ OEM Tech Discussion 14 June 18th, 2010 16:42
Nevada Comanche Smog Legal In Cali jeepprerunner OEM Tech Discussion 6 February 18th, 2008 22:48
4.6L STROKER AND CALI SMOG NAZI'S ladrew SoCal Chapter 7 September 17th, 2006 23:07
anyone in cali swap a HO in a renix yr and pass smog like its a renix? RWKHausSupply Modified Tech Discussion 8 January 30th, 2006 14:55
