Old January 30th, 2017, 19:25
Forestgreenxj Forestgreenxj is offline
01 XJ Rear End Swap Questions
Im pretty new to the 4x4 word and even newer to the Jeep world, but my jeep has the Dana 35 rear end and my end goal is 3.5 in lift and 33's on ot for occasional off road use. I sourced a Chrysler 8.25 rear end out of a 00 jeep for cheap, would this be a good way to go and what else would I need for this swap? Thank you, Mike
Old January 30th, 2017, 19:30
csailors csailors is offline
Re: 01 XJ Rear End Swap Questions
8.25 will be fine for what your looking to do. Nothing needed for the swap other than new U bolts and maybe spring plates? Everything else should be the same.
Old January 30th, 2017, 19:36
trippled trippled is offline
Good idea to check the gear ratios. And yes you will need spring plates. The may be a difference in drive shaft length as well.cant remember tho.
Old January 30th, 2017, 19:51
Last one we swapped driveshaft was the same from D35 to 8.25. At 3.5" of lift your going to need an SYE and get another front driveshaft for the rear anyway
Old January 30th, 2017, 20:03
Gear ratios are the same 3.55's would 3 inches of lift need a SYE?
Old January 30th, 2017, 20:05
I would still suggest it with a late model. Driveshafts are shorter than earlier models. 3" is the cut off usually.
Old January 30th, 2017, 20:11
Will I need the drive shaft from the 2000 jeep to go with the rear end? And who makes the best spring plates or is a plate basically a plate so it dosent matter? Thanks for all the help!
Old January 30th, 2017, 20:24
cherokeefan_1's Avatar
cherokeefan_1 cherokeefan_1 is offline
When I swapped in a 00 8.25 into my 91 I purchased Clayton spring plates, I think. When I torqued the 1/2" U bolts down the plates bent, was not impressed even though they are like 3/8" thick or something. Even my old d35 plates didn't bend much with 1/2" bolts. I torqued them to the spec I was given from the spring shop I got the bolts from.
Old January 30th, 2017, 20:39
Ruff stuff makes some nice ones. Or find some from the jy
Old January 30th, 2017, 22:36
RCP Phx RCP Phx is offline
Don't you have ABS?
Old January 30th, 2017, 23:20
My bad those were ruff stuff spring plates that I used not Clayton. Too many orders from too many places.
Old January 31st, 2017, 04:45
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
D35 and Chry 8.25 do have different length drive shafts. If swapping at stock suspension height use the matching driveshaft to the axle being installed. If swapping with a small lift, use the longer D35 shaft.
Drive Shaft Length
1996.5-2001 ........29 spline 8.25 .... 27 7/8"
1997-2001 ...........D35 .................. 28 7/8"
Drive shaft length measured from center to center of each u-joint on the tube part of the drive shaft for 4.0L with AW4 and NP231.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old January 31st, 2017, 06:32
Nope no abs.
Old January 31st, 2017, 08:18
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Spring plate comparison, OE and IRO ( http://www.ironrockoffroad.com/10481.html ) :
And:
Note you can get new U-bolts from IRO too.
Also note that a piece of 1/2" copper, cut with a tubing cutter and only partially deburred inside (how much to deburr depends on how much rust build up is present on your existing parts) makes for a convenient e-brake cable release tool:
Old January 31st, 2017, 11:06
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Need a sye, no, but it would be a wise option over 3.5" with 33's. Also with 33's on 3.55's you're going to want to regear. Wouldn't go above 30's on stock gears and be able to keep the rig capable for offroad. For just DD and dirt road use probably be fine, but there will be a point where 3.55's just won't do. Good luck with the rig!
8.8 swap questions Thegtwyo86 Modified Tech Discussion 5 October 5th, 2012 13:21
Questions about rear axle swap ... disc brake ok ? blaze one Modified Tech Discussion 3 February 28th, 2010 10:29
ax-15 swap questions... jmeti000 Modified Tech Discussion 1 January 10th, 2009 12:06
nissan, yes nissan, rear axle swap questions dirtdogger17 Modified Tech Discussion 14 May 29th, 2006 01:46
AW4 Swap questions summitlt Modified Tech Discussion 7 June 10th, 2005 05:04
