Old January 24th, 2017, 09:23
Forestgreenxj Forestgreenxj is offline
01 Jeep only Starts After Sitting
So I just bought my first xj its an 01 and it only started after sitting for about 8 hours and I replace the CPS and now it wont start at all, butt will crank and crank and crank, any help would be appreciated
Old January 24th, 2017, 09:48
dan1977p's Avatar
dan1977p dan1977p is offline
Re: 01 Jeep only Starts After Sitting
Put your good CPS back in first to get back to a running condition.
Then put this into google and have fun: jeep xj wont start when hot
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old January 24th, 2017, 11:11
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Test the fuel pressure. Test the check valve leak down. If the fuel pressure is correct, suspect the Crankshaft Position Sensor (CPS) or its wire plug and wiring. Wiggle and inspect all the wire harnesses and wire plugs. Look melted/chafed insulation and corrosion.
Cheap Chinese CPS, often sold with a "lifetime Warranty", are well known to be out of specification or even failed right out of the box. Only buy genuine Jeep engine sensors.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old January 24th, 2017, 11:14
90xj06's Avatar
90xj06 90xj06 is offline
there has been people that have gotten bad parts out of the box. i would try a better quality one.
once it gets running does it stay running and run smooth?
Old January 24th, 2017, 19:25
I have fuel at the rail I pressed the valve and fuel sprayed out, and when she starts up she runs like a dream. And the replacement CPS was from autozone.
Old January 24th, 2017, 20:03
md21722 md21722 is offline
Get one from Mopar.
Old January 25th, 2017, 05:53
dan1977p's Avatar
Do CPS's fail when the motor is hot? I didn't think so. That's why I suggested the search I did. Everything suggested so far seems like the opposite of his issue. Unless I read it wrong, it starts fine the first time but has to sit for eight hours to start again. I bet it just needs to cool sufficiently to make one of the sensors on the intake start working again. Or maybe the wiring to the CPS has sat on the exhaust header and now is toast.
SeXJ Build Thread
Old January 25th, 2017, 11:25
Tim_MN's Avatar
Crank Position Sensors can have intermittent “thermal failure”. This means that the CPS/CKP fails when the engine gets hot, but works again when it cools back down.
The root cause may in fact be something else, but so many "Lifetime Warranty" CPS have been total crap that the CPS cannot be ruled out as the primary cause until it is genuine Jeep part.
Old January 25th, 2017, 14:24
Just bought a mopar cps, and returned the autozone one, we'll see how this goes.
Old January 25th, 2017, 15:14
Just installed my mopar cps it coughed but didn't start, still smelled fuel in the intake so Im thinking spark.
Old January 25th, 2017, 16:28
Just bought a scanner and its telling me camshaft sensor
Tim_MN's Avatar
With the CPS ruled out as the primary cause, a faulty Cam Sensor would make a likely suspect, especially if you have a related trouble code.
Old January 25th, 2017, 20:26
I just replaced the cam sensor with a mopar parat and she started right up! Thanks for all the help guys!
Jeep starts after sitting.....shuts off and then wont start again PlayvorPlayv99XJ OEM Tech Discussion 4 July 23rd, 2014 14:24
Jeep starts only when it wants to TonyBoom OEM Tech Discussion 4 May 4th, 2011 05:33
My jeep starts like a diesel Ben824 OEM Tech Discussion 3 November 20th, 2010 11:40
Jeep isn't sitting level ColumbusXJ Modified Tech Discussion 17 September 28th, 2009 08:26
Jeep starts and then dies out MudDogg OEM Tech Discussion 5 June 15th, 2009 12:45
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
