Old January 20th, 2017, 11:04
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Pre-Production Sneak Peak at Boostwerks Comp Mount
Note that this is not yet a production item. There will probably be some minor revisions to what you see here, but this probably very closely resembles the final design.
When I first bought my XJ I found this site and in reading through interesting threads I found LazyXJ’s hidden winch. That immediately went on my list of mods to eventually accomplish. Then I found Boostwerks’ Ultimate XJ Steering Brace and started trying to figure out how to blend the two ideas. Then in December 2014 the Comp Mount showed up on the Boostwerks website. I have been pestering Bryson ever since. Graciously, rather than getting a restraining order against me, he let me be one of the first guinea pigs to help him work out the final details. I have had this for several weeks now, and while I have not yet finalized my installation I have managed to prove that the Comp Mount fits as it should. There are still some details to be checked (most notably the sway bar) and the weather is interfering with progress, but that same weather is affording me the time to present a bit of a preview. For those who have been waiting, here is what is coming:
Bryson gave me a heads up in the fall that he was getting close to having the pre-production parts ready for me. That gave me time to do some hunting for a deal on a Warn M8000 winch. That is what the design is for. I have a Warn 9000XD, but when I had inquired early on in the process Bryson told me that was an unlikely fit on account of the larger size. Lamentably, no one had any Black Friday deals on an M8000, nor could I find anything leading up to Christmas.
Then Bryson contacted me to say the mount was pretty much ready to ship, and did I want it powder coated or bare? I opted for bare fully expecting I would need to grind and maybe re-weld something. Powder coating isn’t a particularly forgiving finish when it comes to modifications. Bryson also suggested I should go ahead and try the 9000XD as he had made some alterations from the original design and there was a chance the larger winch would fit. Cool.
A couple of days after Christmas the mount arrived. The Varmints were ecstatic to get a large box to play in. Again I ask, why do I spend money on them at Christmas? It could be saved to spend on the Jeep instead. And get more toys like these:
And I pulled out my winch to get a sense of how it would fit in the Comp Mount itself:
It has to be shifted all the way to the right, but it looks like it could fit. Next is to see what kind of interference is offered by the vehicle.
I pulled off the bumper and held the mount up against the radiator support to mark its perimeter with a Sharpie, then took a look at what I thought should be cut out. Because inside corners have a tendency to be stress risers I tried to incorporate as many of the factory holes as I could for the corners of the cuts.
Picture of the marks I made:
Same picture, but with the intended cuts indicated:
The cuts made:
The new opening:
Next, some areas need to be flattened out for the mount to sit flush against the rails. The instructions for the Comp Mount haven’t been written, but Bryson sent me a copy of the instructions for the Ultimate Steering Brace. Those call for flattening the seams with a hammer. I found a hammer would get me two thirds of the way, but the last third would just bounce back. I had better luck finishing it off with a clamp.
On the driver’s side I had a big old glob of weld booger than a previous owner had applied to said seam. That had to be ground down:
And the factory left behind a nice collection of weld boogers on the passenger side. These had to be ground down too:
And I was able to make a first trial fit (note: no winch and no sector shaft support bearing):
That fit told me that I needed to clean up the line of this flange if I wanted to have any hope of fitting my too-large winch in here:
Next step is to mount the winch in the Comp Mount. I knew I needed to rotate the gear box 180 degrees. Warn has a brief note about this very thing right here:
Link: https://www.warn.com/blog/2011/09/27...b_bumper.shtml
And because links seem to go dead over time, the text of that reads as follows:
To make the clutch handle easily accessible, stand the winch up on end
so the housing is straight up in the air. Next, remove the 10 screws
from the end housing then you can lift the winch up about a 1/4" and
rotate it every two holes to the desired position. Reinstall the screws
and you are done.
What they don’t bother to tell you is that you are likely to need a new gasket if you do this:
The rotation was made for the sake of progress and new gaskets were ordered so that detail could be revisited properly before the final install.
Old January 20th, 2017, 11:10
Anak's Avatar
Mostly Harmless
Re: Pre-Production Sneak Peak at Boostwerks Comp Mount
I then was able to attempt the mounting of the winch in the Comp Mount. I thought I could feed the engagement lever through the hole and then line things up, but it would not play nicely. I finally removed it, got things aligned and bolts started and then tried to reinstall it. No luck that way either. This is a detail I am still working on. My goal is to have it accessible through the bumper. When it came to bolting everything up I also had some issues with the gear box interfering with one of the interior gussets, and there was no clearance for the bolts for the fairlead. I initially attributed these problems to my choice of winch, but later Bryson informed me that he forgot to include the spacers that are needed. Production units should come with these. At any rate, I was able to get things assembled well enough to make another test fit:
Note the two pieces of allthread. Those are an assembly aid. At this point I was trying them using the sway bar threads. I have since refined my methods and am using the size of allthread that matches the plates that go in the frame horns. More on this later, but keep it in mind as a very helpful aid.
Getting this unit into place was something I knew would be a challenge. I had asked Bryson about this and he told me he highly recommended a jack, such a transmission jack, and that he liked to have killed himself the first time he tried this. I don’t have a working transmission jack (I have a dead one, but that is another project in and of itself). I didn’t have high hopes for this, but I tried it anyways:
Yep. That is as high as that jack goes. And I am only running about 3” of lift and 235/75r15s. It is going to take a lot of jack for some folks’ rigs. A two post lift and a stand-up transmission jack would be the cats meow. I have neither of those. So bench press it was. I employed a Varmint for starting the nuts and bolts while I held the assembly in place. It wasn’t too bad getting it up, but keeping it there was another matter. Especially with young hands who have neither the experience nor the strength for the task. But we got it done. And no one died. However, I found a better way when removing the unit. More on that later.
Here are some pics of how it fit:
Note the Sharpie marks on the shroud. Bryson had warned me that I might need to trim the shroud, particularly given my choice of winch. This may not be the case if you are using an M8000. I can bolt things in place, but the winch is definitely pushing against the shroud. I doubt the interference will be good for the plastic. The marks show where I need to cut.
Here you can see how close I am cutting it on the passenger side. This fits, but barely.
Here is the fit on the steering gearbox side:
And another, slightly different view of the same:
And here is clearance to the dampener:
And the same, showing a bit of the steering:
When it came to removing this I simply sat down on my creeper in front of the Jeep and put my knees against the bottom of the winch mount, pulled the bolts and lowered it down using my legs. That was a piece of cake, and the reverse works well too. Forget the bench press method. Those with higher lifts or shorter legs may want a rolling stool. Play around with options and find something that works for your combination.
Now it was time to address the sector shaft support bearing. Instructions call for a 1 3/8” and a 1 5/16” deep well socket. The 1 3/8” is for the new, extended sector shaft nut and the 1 5/16” is for the old nut. On mine I certainly did not need a deep well socket for the original nut. A standard socket would have been fine. Check yours before you order anything. The socket for the new nut is another matter entirely. Deep well isn’t deep enough. What you need is extra deep, if you can find it.
When I tried to order my sockets the 1 3/8” was out of stock, so I opted for 35 mm. It is pretty close. Not perfect, but at that size it will do. When it came in I found it too short, so I tried to get a longer one at Napa. No luck on the length, but I will say that Napa’s pricing was better than Amazon’s. I got a second socket and then proceeded to make my own extra deep socket.
Here is the challenge:
I decided to trim both in order to get the joint away from the contact area:
Beveled:
Welded:
Final torque is probably a subject for some personal consideration. Instructions call for 180 ft/lbs (factory spec) with anti-seize (I don’t think the factory calls for that, but I do like something on my threads). If you hunt down the tech specs for Permatex they say to “Reassemble parts using normal torque values.” Personally, I am not so sure about that. From my experience elsewhere, the marketing folks will say just about anything in order to sell a product, regardless of outcome. Here would be the extreme view going the opposite direction: http://benmlee.com/4runner/threads/threads.htm
And this is probably the reasonable compromise position: http://www.garagejournal.com/forum/a.../t-226077.html
I am thinking this rule sounds like the path to take: “Using Never Seize versus dry uncoated steel, multiply the specified torque by 0.65.”
But that is a personal decision. From a “follow the rules so the lawyers don’t take your arse” perspective you may be best off following the directions.
Old January 20th, 2017, 11:16
Anak's Avatar
Mostly Harmless
That aside, back to the Comp Mount.
I had observed that my sector shaft did not exactly line up with the opening for it. Bryson suggested I loosen up the bolts for the steering gear box and try moving it. That did work. With some leverage from a pry bar, like this:
And even at that, it only barely cleared. I think this is one of the changes that will be made in the production units, affording a little more room for adjustment here.
And here is a view of how it clears on the inside (taken through the opening for the fairlead):
And a view from the outside:
Now I needed to try to get everything all together all at once. I made some spacers to solve the problems of mounting both the winch and the fairlead (I expect production units to come with spacers, not necessarily identical to what I did, but effectively the same thing):
And here it is, all together:
With my hand in place to give some sense of clearance:
A side view, looks like a good skid plate to boot:
These next four pictures are to give a sense of clearance and of some of the challenges involved in trying to incorporate additional mounting points in a production piece.
At the driver’s side frame horn, no gap:
At the passenger side frame horn, approximately a 1/8” gap:
At the driver’s side radiator support, 3/8” gap:
At the passenger side radiator support, ˝” gap:
I would still like to attempt to weld in some brackets to tie those pieces in, but that turns this into a fabricator’s piece. I doubt most customers will want to go to those lengths. As it is, this piece could have been sent to me powder coated and I could have a final installation with no modifications. If I were the manufacturer I would not mess with that. I would say job well done.
I still need to deal with the sway bar. Bryson is sending me some of his drop brackets so I can take care of that detail.
I also still need to get the bumper back up and see what sort of modifications are required to run the front bumper. Odds are this is going to work best with something like a pre-runner bumper, but my goal is to keep this as boring looking as I can.
Once I have the bumper figured out I will then try to figure out the engagement lever.
And there is the mounting of the control box and its associated wiring.
More to come, but this should get folks an idea of what the Comp Mount will be.
Old January 20th, 2017, 12:52
XJAZ XJAZ is offline
Very nice. This would go a long way to strengthen and reinforce the front unitbody.
I already have Boostwerks' steering brace
Old January 20th, 2017, 13:33
Goose_XJ88's Avatar
Goose_XJ88 Goose_XJ88 is offline
Thank you for the Eye Candy
Old January 20th, 2017, 13:37
Anak's Avatar
Mostly Harmless
It occurs to me, I have neglected a few potentially relevant details regarding the vehicle used in this fit test.
It is a '96.
It has HD Offroad Engineering's frame stiffeners in the front. These have no impact on the fitment. Only possible issue I can see would be if they were positioned such that repositioning of the steering gearbox were limited.
It has a JCR Offroad steering spacer. This pushes the gearbox over a bit further than the stock spacer. The slots in the Comp Mount take care of this just fine.
Old January 20th, 2017, 15:37
Anak's Avatar
Mostly Harmless
dadgummit!
Post up a bunch of pictures and my hosting service takes a dump. For the third time in as many weeks.
Inmotion hosting doesn't seem to have their act together particularly well lately.
Pictures will be back. At some point.
Old January 21st, 2017, 10:24
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Beautiful, but too much effort...I'll stick with a plain old winch bumper
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old January 21st, 2017, 12:53
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter Treasurer
Looks slick. Cant wait till this goes into production. He will take my money.
Old January 21st, 2017, 16:09
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
On a side note, I'm going in for some much anticipated surgery next week, but getting these to market will be my primary goal once I've recovered.
Thank you again for your help Tom!
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old January 21st, 2017, 16:29
I have been waiting over a year. Ill wait patiently some more. Good luck with your surgery. Speedy recovery.
Old January 22nd, 2017, 16:27
themauler's Avatar
themauler themauler is offline
Action Fab on Pirate4x4 and I believe he was on here for a period of time makes the stubby bumpers. His website is called Off Road Specialties. His bumper is what I fabbed mine out of.
Just another alternative to folks who want a hidden winch plus a bumper
Old January 22nd, 2017, 17:42
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
Don't understand the thread jack but those bumpers don't look like they compare close to Bryson's winch mount. His looks to tie in to the uniframe better plus sector shaft support
Old January 22nd, 2017, 18:23
Anak's Avatar
Mostly Harmless
I think the idea is that the stubby is a compatible bumper, not an alternative product.
Old January 22nd, 2017, 19:16
themauler's Avatar
Didn't intend for a thread jack approach. It is really apples to oranges in this case. This is solely a winch mount and steering brace. The alternative is a bumper and winch mount. Both have offer great approach angle and winch protection which a lot of people prefer.
Since this is "pre-production" and I have not seen this piece in person I figured I would voice my only concern. All lateral alignment appears to be controlled by the mounting bolts and the fitment around the bolts. I have no idea how much un unbraced steering box moves during normal offroad use but if there is a hard lateral pull and the whole mount slides say 1/4" to one side and takes the steering box shaft with it, will the steering box survive that? I will put on my flame suit now
Sneak Peak:Rough Country Winch Bumper Blind Driver Modified Tech Discussion 32 September 21st, 2011 10:20
Back in production....Motor Mount Brackets Tom_T&Js_Offroad Vendor Advertisements 2 February 5th, 2009 17:09
Sneak Peak - Warrior Products XJ Rear Bumper WheelinJR Jeep Picture Showcase 7 June 21st, 2008 17:29
Sneak Peak, XJ Low Profile Roof Rack jcroffroad NAXJA Vendors Info and Feedback Forum 36 June 19th, 2008 21:22
sneak peak Led Modified Tech Discussion 43 July 16th, 2004 16:01
