Old January 14th, 2017, 08:05
tricker tricker is offline
98 XJ Coil Driver
Can someone tell me where the signal wire for the coil ties into the pcm?
Old January 14th, 2017, 08:39
RCP Phx RCP Phx is offline
Re: 98 XJ Coil Driver
Terminal A7
Old January 14th, 2017, 10:29
thanks!
Old January 15th, 2017, 14:06
I have no ground switching occuring....
Also my CEL doesn't come on with ignition start any longer....is the PCM fried?
Old January 15th, 2017, 16:34
chuck619120 chuck619120 is offline
so why not fix your ground?
Old January 15th, 2017, 18:39
I ran directly from pin 7, pin 7 is constant ground
Old January 16th, 2017, 07:15
90xj06's Avatar
90xj06 90xj06 is offline
make sure the fuses are all intact for the pcm power. pin a2 should have 12v when in run or start
a22 has 12v constantly
a31 and 32 are ground.
check those first.
Old January 17th, 2017, 16:56
check those first.
Firstly, thank you for your help!
These check out, still no spark....I've thrown all the parts at it I know to and even some I don't
Are you willing to guide me a little further to remedy the issue?
ALL help is MUCH appreciated
Old January 17th, 2017, 17:52
Jeep Driver Jeep Driver is offline
Are you getting a signal from the CPS?
Old January 17th, 2017, 18:04
I only have a digital multimeter so I don't know a really good way to tell
Old January 18th, 2017, 11:58
90xj06's Avatar
with a digital meter set to ac it may show something on it. if you able to just grab a cheap analog meter that would be the best way to check
Old January 23rd, 2017, 18:41
appear to be getting signal....
Old January 23rd, 2017, 19:48
JeepNoob JeepNoob is offline
I'd back-probe the signal wire on the cam sensor (it's inside the distributor, that's what the distributor plug is for.) and check that next. I don't know about the '97 and later XJ's, but my CEL is literally a peanut-style light bulb with a cover over it. Lack of CEL could be something as simple as a burned-out bulb.
Old February 20th, 2017, 18:34
definitely getting signal from the crankshaft position sensor... no spark
Old February 21st, 2017, 06:54
90xj06's Avatar
how are you checking spark? how are you checking ground switching on A7? are your fuel injectors firing?
Driver Side Front Coil Rubbing 4jeep4 Modified Tech Discussion 10 November 13th, 2013 17:41
Wanted: Coil pack for 4.0 coil on plug Brandoson Arizona For Sale/Wanted 0 October 17th, 2012 21:45
front driver side coil spring perch snapped bijjim Modified Tech Discussion 1 June 8th, 2006 21:39
