Old December 12th, 2016, 18:12
bahumutx13 bahumutx13 is offline
93 XJ - Trans 2nd Gear Issue
Morning,
I have a 1993 XJ with a rebuilt 4.0 (10k miles,) an AW4, and a NP231 and 32" tires.
So I was on a road trip, about 400 miles into it, and was heading up a hill. Well it blew out the trans cooling lines and dumped most of my ATF onto the exhaust in a lovely cloud of smoke and burnt the rest of it. The jeep shuddered a bunch and died.
I coasted over to the side of the road and eventually got a tow truck. I then had a mechanic fix the coolant lines (Previous owner had put 3 rubber o-rings instead of the plastic piece to keep the clip in place.) He then did a full ATF flush and I was on my way.
Which leads me to my current problem. The jeep is now having issues going into 2nd gear. From takeoff I'm solid, but as soon as it drops into 2nd I hear a lot of rumbling, very low power, and it seems like its going to die. If I floor it it'll drop back down into 1st and be fine. Or if I get up to speed and get into 3rd and OD then I'm good. It will cruise down the highway just fine. (It's made it over 500 miles without a hitch.)
So my main question is: is the trans f'd? Is that a common symptoms of something internal? Could it be something else like the torque converter? Any way of troubleshooting it further?
Sorry for the long read, just hoping to get some more insight before I do something like buy another trans as I know virtually nothing about transmissions. Thanks for the help.
88 XJ trans issue XJeeper87 OEM Tech Discussion 9 October 9th, 2011 10:45
2nd gear trans issue jeepboy73 OEM Tech Discussion 6 June 24th, 2010 23:56
i got two problems with my 1998 XJ a trans issue and airbag issue Trey98XJ OEM Tech Discussion 12 March 29th, 2010 07:25
torque converter issue (tricky issue need some gear heads) black_goose OEM Tech Discussion 20 September 8th, 2009 22:09
aw4 trans issue bhamer2 OEM Tech Discussion 1 December 3rd, 2008 21:38
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
