Old December 12th, 2016, 06:08
SavedDad SavedDad is offline
Open Open or Weld the rear
Hiya gang !! looking for some advise.. both the diffs on my 95 are open..30 up front, 8 1/2 rear...I still wanna be able to drive her on the paved road.
This is a budget build and I'm looking for the cheapest way gain the traction. Will welding the rear be a mistake? or just save my coins for a locker?
thanks - Ken
Old December 12th, 2016, 06:22
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Re: Open Open or Weld the rear
Absolutely save for a locker.
Dirk DeYoung--Member #176--National Vice President, SEC President
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2013 WKII (SUZIE)...2006 XK (TOW RIG)
Old December 12th, 2016, 07:20
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
I'd throw an Aussie in up front
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
Old December 12th, 2016, 07:56
RattyXJ RattyXJ is offline
Lokka brand lockers. 424 shipped front and rear.
Old December 12th, 2016, 09:17
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Welding a differential should only be done to a trail rig.
Any of the Lock Right style Lunchbox Locker will be fine. If you are installing only one locker, a rear locker is more effective than a front locker
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old December 12th, 2016, 11:02
can I run this in the rear and open in the front?
Old December 12th, 2016, 11:28
Tim_MN's Avatar
IMO this will give the best results when only installing one Locker or one Limited Slip.
Old December 12th, 2016, 11:33
VAhasnoWAVES VAhasnoWAVES is offline
i would argue the opposite.
Old December 12th, 2016, 11:36
Cottontail's Avatar
Three-De Off-Road
I'm kind of with VA on that one. I ran mine with just a lunchbox locker in the front (Aussie) for a couple years. I finally added a Spartan last year to the rear, and frankly was underwhelmed by the amount of added traction that second locker added. I felt some, but was expecting more. Perhaps I had the benefit overinflated in my mind. If I needed to go back to one locker again in the future, it would be the front.
Perhaps it is terrain based a bit. In the south, I think I use the front to pull more than I use the back to push.
Old December 12th, 2016, 12:36
dan1977p's Avatar
dan1977p dan1977p is offline
That's what I've always heard. If you're climbing, throw it in the rear, otherwise, the front. At least in the front, in 2wd, you don't have to 'out drive' your locker. In the rear, you have to learn to drive with it or deal with increased tire wear.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old December 12th, 2016, 14:14
NAXJA Forum Addict
My old 94 ran an Aussie up front and a ford 8.8lsd rear
The front Aussie was an amazing improvement
John V.
Old December 12th, 2016, 15:22
StinkyFab's Avatar
StinkyFab StinkyFab is offline
NAXJA Supporting Vendor
Which end to lock first is very debatable, and I could easily debate either side.
What's really not debatable is that welding it is a bad plan for something that sees street duty.
Dallas Ashley
WWW.STINKYFAB.COM
Motor Mounts, Fabrication tools, and Custom stuff for your Jeep!
Old December 12th, 2016, 15:55
TRCM's Avatar
TRCM TRCM is offline
I've always run, & prefer the rear locked.....personal preference and how you will use it varies, so you should decide based on this.
I prefer rear since I am use to how the vehicle reacts and since I use 2wd 99% of the time I am off road.
Remember, the rear axle is always pushing the vehicle forward. The front axle is only pulling when in 4wd. Unless you want to be in 4wd to gain the extra traction, put it in the rear axle and forget about it.
For me, 4wd is the last ditch effort, so I don't wanna be running around in it all the time. I want to run around in 2wd with a locked axle, knowing that if I get stuck that way, I can put it in 4wd to add the traction from the front axle, and drive out (hopefully). If you are in 4wd when you get stuck....you just may stay stuck since you have no additional axle to engage and add traction to help you get out.
Welding is always a bad idea on the street. No debate there.
Old December 12th, 2016, 16:07
sinat01's Avatar
sinat01 sinat01 is offline
So which is better if you live somewhere and you gotta deal with snow? ive heard that auto lockers have a steep learning curve in snow, but what about a spool, or are they more for off road?
Old December 12th, 2016, 17:08
Tim_MN's Avatar
I believe in weight transfer, and use it to my advantage. Going up a hill, or obstacle, the center of gravity and the vehicle weight transfers towards the rear axle. At a 30 or 40 degree climb the rear axle has most of the vehicles weight on it, and thus the most traction potential. I would rather have 100% traction of a locker on the axle with 80% of the vehicle weight/traction potential, than have 100% traction on the axle with barely any weight or traction potential on the tires at all.
If you are only going to have one locker, it should be in the rear axle where it will do the most good.
Neither my front Locker nor rear Locker has any effect upon the tire wear, however the front locker has annoying behaviors in Minnesota winters.
The locker in my XJ performs and behaves very similar to the Limited Slip it replaced, and very similar to my old Ford Ranger with the 4x4 Off Road package and Limited Slip. The benefits of a rear Locker or Limited Slip in Minnesota winters is well worth having to drive slightly more carefully. A spool is just as annoying as a welded axle, but easier to return to normal.
4.56 complete axles 30 & 8.25 open/open Hammered NAC Classifieds 8 November 24th, 2012 20:22
Open Fuse open Ignition Hot XJrealm Modified Tech Discussion 5 June 15th, 2012 19:51
dome lights dont come on when doors open but do when hatch is open 90Pioneer OEM Tech Discussion 8 December 7th, 2010 08:50
Rear Hatch Won't Open Monstermx117 OEM Tech Discussion 19 November 11th, 2009 18:08
any problem with leaving axles open/open? moparjim1987 Modified Tech Discussion 30 October 7th, 2009 07:06
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
