Old December 11th, 2016, 08:49
evinruderider evinruderider is offline
98 xj sport goofy abs
First time xj owner and forum user. So heres my symptoms , I've noticed that the brake pedal is stiff when you first get in it without starting the motor, yesterday the abs would come on under moderate brake pressure on dry roads, today we have snow and it won't come on at all, and no ABS light on the dash. I haven't checked fuses or anything yet just looking for a good place to start. Thank you!
Old December 12th, 2016, 10:29
90xj06's Avatar
90xj06 90xj06 is offline
Re: 98 xj sport goofy abs
does the abs light turn on when you first turn the key on?
the abs works by detecting wheel speed. if one locks up it will trigger.
once had a ford that would not detect wheel speed slower than 5mph and would always activate when braking. never triggered a light for that.
Old December 12th, 2016, 10:58
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
My 97 XJ's antilock never works very well and one day the ABS light came on.
There is very little information available for troubleshooting the ABS system.
After screwing with it for a few months, I fixed the problem by dumping the D35 and building a 8.25 axle, to replace it.
8.25 XJs do not have ABS or an easy way of installing the sensors on each side of the rear axle.
Cured the ABS light by pulling the fuse..good riddance.
Best advice is to inspect each wheel's sensor for damage, clean each sensors plug and any plug that is part of the ABS system. Check the ABS fuse.
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Goofy no start? cherokee4fun OEM Tech Discussion 14 October 29th, 2009 14:16
Goofy 242 TC case issue???? cherokee4fun OEM Tech Discussion 15 January 4th, 2009 17:47
goofy search? muddeprived User Support, Questions and Suggestions 1 January 9th, 2008 17:31
Tail Lights all goofy Vanquish OEM Tech Discussion 4 February 28th, 2007 14:11
Goofy stereo problem Phil Modified Tech Discussion 5 October 25th, 2004 01:13
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
