Old December 8th, 2016, 19:32
tuckholladay tuckholladay is offline
NEWB Needs Post-Lift Install Guidence
OK I hope this is the correct place to post. I didnt see a build thread forum.
I have been trying to get help over at Cherokee Forum, but no one is that interested. Maybe my issues are boring.
I recently purchased a shiny new truck, so now I can finally play with my trusty Cherokee of almost a decade and have it in pieces in the driveway and still have something to get around with. So I am ready to play.
I purchased the Rubicon Express 3.5" Superride kit and have kind of successfully installed it. It is up on the suspension, I can drive it and it doesnt fall apart, but I am definitely getting some drive line vibrations. Low speeds too, I have only tested it around the block.
I did the 1" T-case drop
I have not put any shims between the leafs and the rear axle
I changed all the U-Joints in the front and rear drive shafts
I torqued everything back to spec to the best of my knowledge
One bad thing that happened is I knocked off the little balance weight on the front drive shaft while I was changing the UJoints. I JB Welded it back on, but Im thinking this could be the problem.
I know I should get an SYE, go bigger etc., but I am just getting started and trying to stay semi budgeted.
Anyway I feel like I am at a point where I should take it to someone and get the tires put on, get an alignment and see if there is still a problem. Think I just need to get the front driveshaft re balanced? Do I need the shims for the rear? Does anyone have someone they would recommend to take a look at in in Northern NJ?
Thanks in advance.
Old December 8th, 2016, 20:03
Vernicious Vernicious is offline
Re: NEWB Needs Post-Lift Install Guidence
Pull your front shaft and run it to see if you still have a vibe. Pay attention to how it feels. Then pull the rear and put the front back in, and run it to see of you have a front vibe. Notice how that feels as you may have more than one vibe. If you have a rear vibe it most likely is shims. A front will probably be the driveshaft. My front has a vibe at the slip joint.
Old December 9th, 2016, 11:11
Ok forgive me if this is an incredibly stupid question, but are you saying drive it with one shaft on at a time?
Old December 9th, 2016, 12:43
clydefrog's Avatar
clydefrog clydefrog is offline
Do the front like the previous post from Vernicious. See how it feels like he said.
It doesnt sound like its in your tires based on the fact that it does it at low speeds. Sounds like drive line. Do you feel it in the steering wheel or the seat?
He doesn't have SYE yet.
Old December 10th, 2016, 14:20
Yes, this will make it so you know exactly where the issue is coming from.
Old December 10th, 2016, 15:08
sinat01's Avatar
sinat01 sinat01 is offline
could one of the shafts be out of phase?
Old December 10th, 2016, 15:57
LKN_xj LKN_xj is offline
You can't swap the front shaft since he hasn't done a SYE yet. Get yourself some wide fender washers and start stacking them inbetween the TC crossmember and the spacer you have in there. It's cheaper than buying a 1.5" kit plus you probably still have .5" of thread left going into the unibody. This will at least tell you if it's DS angle related then you can fix it correctly.
I installed the 3.5 RE lift and got about 4.5-5" out of it, so it's well out of the slip yoke operating range.
You're going to eventually need a SYE and pinion correction shims but the spacer will work till you figure it out.
Old December 10th, 2016, 16:21
md21722 md21722 is offline
It is perfectly fine to pull the front driveshaft and see how it does. Even changing ride height within factory specs such as replacing sagging rear leafs can make a u-joint act up for a few weeks. However, in your case I'd guess you need to look at your rear driveline angles. You may need to do something in the front as well, unless you used longer/adjustable lower control arms.
Old December 11th, 2016, 12:10
acruz95 acruz95 is offline
Old December 12th, 2016, 15:53
Ok. Maybe I should just order the SYE.
Old December 12th, 2016, 15:54
The kit did come with new control arms
Old December 12th, 2016, 20:21
Not a bad idea. Mine didn't stop vibrating till I did an SYE.
Newb RE track bar install q kidarkitect Modified Tech Discussion 7 October 13th, 2009 22:43
Another newb lift question Jeepcrush4 Modified Tech Discussion 10 October 12th, 2009 22:34
Dreaded Newb Post - Lift Question NEOhioHick Modified Tech Discussion 30 August 14th, 2008 12:49
need guidence about oils and coolants regev OEM Tech Discussion 4 May 20th, 2005 13:32
in need of guidence regev OEM Tech Discussion 1 September 6th, 2004 11:29
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
