Old December 7th, 2016, 20:55
ID96XJ ID96XJ is offline
bigger intake hose?
Any suggestions for replacing the convoluted stock air intake hose with something that isnt as restrictive? I'm wanting to retain the stock air box and plan to route it into the cowl.
Old December 8th, 2016, 07:31
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: bigger intake hose?
What makes you think it is restrictive at all?
Old December 8th, 2016, 11:31
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Buy some Mishimoto silicone intake bends and some aluminum tube.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old December 8th, 2016, 17:36
csailors csailors is offline
The stock hose is made that way to kill sound. I assure you the volume is more than sufficient for your 4.0 just not as smooth of flow. Which in reality isn't affecting your performance in any measurable amount.
But if you are planning on running it in the cowling, noise is clearly not on your list of worries.
warm air intake hose? CharlieMopps OEM Tech Discussion 13 November 19th, 2008 20:43
Intake Heat hose delete? stephenspann27 OEM Tech Discussion 2 October 3rd, 2008 10:15
air intake hose BigPoppaXJ Wanted: Private Party Only 4 March 17th, 2007 17:10
air intake hose BigPoppaXJ OEM Tech Discussion 4 March 17th, 2007 10:58
Heater hose goes into intake manifold on '86 2.5? CameronB OEM Tech Discussion 1 November 28th, 2005 17:23
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
