Old December 7th, 2016, 18:08
shmicah shmicah is offline
Fast mechnical tick/whirl from intake manifold
Was digging around for vaccum leaks on the 99 XJ.
There is a very distinct mechanical clicking/whirling sound that is intermittently happening somewhere near the air intake of my intake manifold. It almost sounds like one of those sensors there.
It'll make the nosie for like 10-15 seconds, then stop for a bit, then randomly start again. It makes a very consistent rhythmic click - like a mechanical switch opening/closing very fast.
All my googles lead to exhaust leak or lifter tick. I have the lifter tick so I know its not that. I don't think its exhaust leak either as my RPMs are normal, and the car drives wonderfully. I just have very bad cabin vibes when sitting in gear with brakes on.
I took a hose and listened and am very confident it is near the TPS. Are any of those intake sensors known to have a relay or make this noise?
Old December 7th, 2016, 20:15
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Fast mechnical tick/whirl from intake manifold
A loud fuel injector?
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old December 7th, 2016, 21:12
ID96XJ ID96XJ is offline
Could it be the IAC?
Old December 8th, 2016, 06:25
90xj06's Avatar
90xj06 90xj06 is offline
the iac is a stepper motor and when they get stuck they do make click like noises. but the iac is so small im not sure you could hear it.
Old December 8th, 2016, 08:12
Possible but it doesn't sound like its coming from there. I know its hard to be confident of that though. I pulled each FI and the XJ stumbled every time so they are all working correctly. Next time I hear the tick I'll do it again and see if it stops.
IAC is definitely in the area I am hearing it. It is very faint and I have to put my head up to the manifold to really hear it. You would never hear it with the hood closed or from the cab.
I recently had the manifold removed and sitting the garage for ~6 months. Perhaps the IAC got dirty or gummed up? I cleaned it a while back, but didn't really bother cleaning again before throwing it back in.
I'm just tracking down a rough idle, and I know my brake booster is bad so hoping its just causing a minor vaccum leak. So I will tackle that first and if it doesn't make a difference I will troubleshoot the IAC. My only problem with that is how smooth the RPMs are.
Thanks yall
Old December 8th, 2016, 08:16
dan1977p's Avatar
dan1977p dan1977p is offline
Does the rough idle change if you plug the brake booster line? If not, that's not your vacuum leak.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
90xj06's Avatar
iac does control the idle speed and if its all gummed and not working that could be a problem.
Old December 8th, 2016, 08:26
I will try this out. Either way I know the booster is bad, I have a stiff pedal that won't go away. I should be more specific too - the rough idle is a low frequency cabin shake that only happens when sitting in gear (R/D) with my foot on the brakes. If I'm in P, N, or driving - it's smooth.
When you say speed are you talking RPMs? I idle very steady at ~700RPM and it barely budges. Still worth cleaning again like you say.
Old December 8th, 2016, 08:31
90xj06's Avatar
its easy enough to do. just pop the 2 screws out and get a soft brissle brush. also take a look into the hole and see if its all yucky.
Old December 8th, 2016, 08:56
RCP Phx RCP Phx is offline
It's on the other side of the motor, but the purge valve makes similar sound.
Old December 8th, 2016, 09:17
Yup, heard that one yesterday. Similar "sound" but this one is MUCH faster (and fainter) than the purge valve.
Intake manifold and exhaust manifold gasket replacement.... 1990Pioneer OEM Tech Discussion 4 August 9th, 2011 05:24
Exhaust manifold/Intake manifold FS H8PVMT NAC Classifieds 1 November 4th, 2010 11:27
Tick, Tick, waiting for BOOM PoopJeep OEM Tech Discussion 26 March 5th, 2010 08:52
97+ intake manifold and performance exhaust manifold BigG Wanted: Private Party Only 5 September 22nd, 2006 18:45
98 Cherokee starting to TICK TICK TICK...What is wrong? joey99jb Modified Tech Discussion 16 January 1st, 2005 22:40
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
