Old December 7th, 2016, 13:52
phuddleston phuddleston is offline
Rubicon Express control arm squeaking
I have the RE 3.5 inch super ride kit, which has the fixed lower control arms. From the time I installed it, the front control arms would squeak pretty bad. I confirmed this by loosening them past where I would feel safe driving much to see what happened. While not torqued to spec, they would not squeak, but they would pop when I turned, etc. due to being loose.
I have greased them until the grease is oozing from everywhere on multiple occaisions. I installed this lift in March, so it has had 9 months experience. It has neither gotten better or worse in this time. Upon inspection, the bushings look fine and I can't see any damage, so it may just be an annoyance.
Is this a known issue with RE bushings? I tried searching some to see if I could find anything out about whether others were experiencing this, but didn't find much. If someone thinks that I should replace the bushings, what would the recommendation for those be?
Thanks,
Paul
Old December 7th, 2016, 14:19
BRIANHO13's Avatar
BRIANHO13 BRIANHO13 is offline
<- Yum Chocolate
Re: Rubicon Express control arm squeaking
Are they the poly bushings?
H.D. Offroad Engineering LLC
Now Selling Barnes4wd, let me quote your next fab project
Old December 7th, 2016, 15:58
This is the replacement bushings that Rubicon Express has with the Super Ride name: http://www.rubiconexpress.com/Suspen...=R%2FERE3 704
I am not sure that these are the same. I seem to remember that when I put them in the control arms, that the soft parts were split and I had to grease them up and put half in from one side, then half in the other. Then, there was just one crush sleeve that I had to beat in the middle of them. So, if you hit the link I put up top, the soft and hard parts were almost opposite, if that makes sense. 2 soft parts and 1 hard.
Also to add: If poly is cheaper, then that is probably what they are.
Old December 7th, 2016, 20:31
ID96XJ ID96XJ is offline
I had those control arms on mine for several years and they didnt seem to squeak. Mine had rubber bushings. They look like the bushings in that link.
I just switched to WJ lowers when I did control arm drop brackets.
Rubicon Express Control Arm Bushings dart70LA Modified Tech Discussion 5 September 21st, 2012 17:56
WTB : Rubicon Express Upper Control Arms BigBearMang SoCal For Sale 2 March 24th, 2010 09:49
Rubicon Express Control Arms 2000bluexj NAC Classifieds 22 January 22nd, 2010 20:50
