Old December 6th, 2016, 14:26
Dragonlich1961 Dragonlich1961 is offline
Interesting find at jy.
While pursuing a local pick and pull I stumbled upon an 86 four door auto 4*4 Xj. Yes powered by the the anaemic 2.8 v6 from GM.
What was more interesting was the two switch panels located to the left and right of the steering wheel. For comparison, my 94 has on the left, fog and defrost. Right is blank and rear window.
The 86 had defrost and rear window on the right side of the column, left side was missing. What would have been on the left side, I'm use to the standard set up of (left to right) fog defrost tranny and rear window for the renix era? I'm curious and I like to collect the factory rare options, sound bar, 2 door rear vent glass. Front vent glass, door pockets and three point door handles.
Old December 7th, 2016, 06:58
90xj06's Avatar
90xj06 90xj06 is offline
Re: Interesting find at jy.
looks like it was either blank or just had the fog lights
here is a picture of an 85 interior https://www.cargurus.com/Cars/1985-Jeep-Cherokee-Pictures-c6790?picturesTabFilter=INTERIOR#pictureId:undefin ed&pictureId:39086230
Old December 7th, 2016, 10:30
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Early xj including some renix had the switches in a different order in the dash. The defrost and wiper are in the same order in mine and I think some of the renix (probably changed with the transmission switch for the aw4) left is the fog lights, and I don't think anything else, but I'll look may the switches and wiring again since its all apart.
Old December 7th, 2016, 11:46
old_man's Avatar
old_man old_man is offline
I have been looking for the filler panel for the right side with no switches. I haven't had any luck.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old December 7th, 2016, 14:03
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Like this? I may have a spare somewhere.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old December 8th, 2016, 10:27
old_man's Avatar
Actually there was one where the knock outs were not there for the switches. I actually had one and it got lost in the move. I can modify one like you show and have the pebbled ABS that matches but was hoping not to have to.
I want to mount a vacuum or trans temp gauge in there, or maybe my Renix Scan module. I guess I could just mount the scan module and add some code and a hookup to display the vacuum and trans temp on it.
Loveland, Colorado
Old December 8th, 2016, 12:16
90xj06's Avatar
is your renix scan module the REM?
Old December 8th, 2016, 13:12
old_man's Avatar
No. I have broken the code for the Renix ECU and I am starting to build a small Renix scanner that can be used to read out all the Renix readings. It will be a bit larger than a credit card and have a color touch screen. I plan to mount it to my dash so I can see what is going on at any time. I run a 4.7L stroker and have an AFR gauge and mess with the fuel trims.
Loveland, Colorado
Old December 8th, 2016, 13:24
90xj06's Avatar
oh interesting one of the guys i follow on youtube did just this same thing.https://www.youtube.com/watch?v=xqAARi9Q3Rc
i should be getting one soon.
Old December 8th, 2016, 20:17
Piece of Fish!
I should be getting a 3d printer soon. I am considering attempting to make blank plates to do whatever with.
You may find this interesting Waterhammer OEM Tech Discussion 12 December 24th, 2010 15:40
Interesting find..... CrankyYankee North Atlantic Chapter 5 December 10th, 2008 07:03
I always find it interesting RichP Non-Tech / Off Topic 0 August 24th, 2005 22:29
An interesting find... RTicUL8 Non-Tech / Off Topic 5 June 17th, 2005 12:34
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
