Old November 30th, 2016, 20:55
hjeepxj's Avatar
hjeepxj hjeepxj is offline
231 VS 242 and a sad, funny story
I have been accumulating some parts for my new build and I just took delivery of my TNT long arm kit today. As I'm getting the pack list out, I read I ordered the one for the 231 Tcase...for some reason, now, after I have already taken delivery of the LA kit, I say to myself "let's verify the Tcase is a 231"...it's a 242...
F'ing assumptions. I can't believe I bone headed that. LOL. Life goes on.
Reason for my post - what are the physical differences? It appears that it may only be the Tcase skid part of the new x-member that is different....is this the case? OR will I need to ship back the whole x-member?
One of my first thoughts also was to find a 231 and swap it in to avoid having to switch x-members, however after some quick research it appears the 242 is a little more versatile. Is this information correct:
"The difference is that the 242 has an extra differential component to it.
The 231 forces the front and rear tires must turn at the same speed. Bad for dry surfaces. PART TIME.
The 242 allows the front and rear tires to turn at different rates from each other because of the differential in the middle of the transfer case. FULL TIME" ?
End goal in a year or two will be an Atlas II, FWIW.
2000 XJ 5.5" Lift w/Deavers and TNT arms, 30 front w/Super 30 kit, ARB, truss, etc. 44 rear w/35 spline alloys, ARB, Wilwood discs, truss, etc. Hooligan stiffeners front to rear, Hooligan fenders, Trailready front bumper, JCR rear bumper w/tire carrier. *under construction*
Old November 30th, 2016, 21:37
ehall's Avatar
ehall ehall is offline
Re: 231 VS 242 and a sad, funny story
The outer case of the 242 is larger (stronger). It will hang a little lower. You may need to get a new center
As for the other question, yes the 242 has an additional AWD mode that allows the wheels to turn at different speeds, which is wonderful on the street in rain and snow, and also handy on tight trails that don't require 4-Low
my '91 beater rebuild
Old December 1st, 2016, 05:03
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
231 can have a Hack n Tap or a HD SYE. 242 only can do Tom Woods or Hack n Tap SYE.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old December 1st, 2016, 06:57
hjeepxj's Avatar
Okay, thank you for the info. Just as I suspected, hopefully I can just switch the Tcase skid part of the TNT arm set - I'll post the verdict back here.
You are a wealth of knowledge.
I had read this, if I was keeping the tcase long run and not looking to do an Atlas II, I would take this in to consideration.
Good news is the hack-n-tap I ordered from IRO will most likely work.
Old December 1st, 2016, 08:47
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I would swap a 231 in. They don't have as many features and are mathematically not as strong, but in practice they are more reliable and less expensive to do an SYE on, which it sounds like you are going to require.
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
I would try and see if the skid comes with enough room to fit with the 242. The actual size difference is surprising though. So you may have to swap something.
Old December 1st, 2016, 09:23
ehall's Avatar
AA has a real SYE kit for the 242, I have it in mine
http://www.advanceadapters.com/produ...ixed-yoke-kit/
Old December 1st, 2016, 10:07
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
Does the 242 have a 6 gear set or 3?
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old December 1st, 2016, 14:24
srb531 srb531 is offline
it is only the bolt on rear part for the t case.my tnt kit came w/ the 231 skid & i have a 242 , it only took some minor adjustments to make it work. the 242 skid will hang lower then the 231 one.
Old December 1st, 2016, 16:54
ehall's Avatar
The stock low range planetary is the same 3 pinion setup as the 231 but you can use the 4 or 6 pinion planetaries from ebay (I did).
The AWD differential also uses planetary gears. Early models used 6 pinions, layer models used 3. I have only had one 6 pinion differential, very uncommon and hard to find in good condition.
Sent from my SM-G935V using Tapatalk
Old December 1st, 2016, 20:34
hjeepxj's Avatar
It's just not worth it IMO (for my situation). I did confirm with Iron Rock that the Hack and Tap SYE that was on a great sale ($60) for Black Friday will work on a 242. Most likely, an Atlas II will be going in to this Jeep next winter...I just don't want to spend toooo much energy dinking around with swapping in a 231.
Great reference pic! They are quite a bit bigger!
GOOD INFO! This is exactly what I was looking for. What were the adjustments you had to make?
Old December 2nd, 2016, 11:58
cal's Avatar
cal cal is offline
If you plan on putting an atlas in later, I'd get the crossmember for the 242 before you start.
That's a LOT bigger, and won't fit over the 231 one.
Old December 2nd, 2016, 12:15
hjeepxj's Avatar
Very good point, gracias.
Old December 3rd, 2016, 06:21
ehall's Avatar
Should not post while on the road. The differentials all used 3 pinion gears, but the early models used 6 bolts to hold the planetary together, while later models only used 3 bolts
Old December 3rd, 2016, 07:56
hjeepxj's Avatar
UPDATE: I called TNT after thinking about what Cal said. I got lucky - TNT is coming down to CO for the Christmas Caravan - they offered to bring the 242 tcase skid with to swap me.
TNT rocks!
Funny story... RTicUL8 Political Discussion Zone 3 October 30th, 2008 14:47
funny story XJelmo9 Intermountain Chapter 5 February 22nd, 2008 09:37
funny story Gravesdiggerxj Intermountain Chapter 5 February 15th, 2008 09:54
Funny SYE Story M4Madness Modified Tech Discussion 4 February 17th, 2007 22:15
funny story 2offroad Non-Tech / Off Topic 1 October 20th, 2004 07:13
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
