Old August 5th, 2016, 13:05
RCP Phx RCP Phx is offline
The Quest for a good 0331 replacement???
I've been doing my home work to find a replacement for my 2k XJ. So far I haven't come up with a lot, I've seen the TUSY head and several like it but they are fully loaded heads and I would want bare one! I know that HESCO has a ready to go Aluminum head when I found this one - http://www.edelbrock.com/automotive/...ads/jeep.shtml
I really don't want a Aluminum head on a off-road vehicle, so I called Hesco about their CNC cast bare head and was informed that they don't have any available. I asked them about sending them a head to do a CNC job on and they said that they only do them in "batches" and couldn't even give me a time frame.
Old August 5th, 2016, 13:35
Ralph77 Ralph77 is offline
Re: The Quest for a good 0331 replacement???
I am always poking around about that too. Own a '00. Best I can tell no issues, 155K, but ya know. Just 2 days ago on Craigslist I found a guy, local to me, selling a '03 WJ motor with the TUPY head for $50. I offered him $50 for the head, cause I have no use for the motor (my research indicates it won't work), and he said sure why not. Picked it up yesterday. So best case scenario I have a head that can be rebuilt. Worst case scenario a $50 door stop. At some point I will get it checked and go from there.
Old August 5th, 2016, 13:44
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Why dont you want an aluminium head for an offroad jeep?
Old August 5th, 2016, 20:56
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
I'd go with aluminum if price isn't the issue. There really isn't a downside...especially considering that you want to "build" the motor. You can run higher compression without detonation, engine will run cooler (all other things being equal), it will be lighter, chamber temps will be more stable, no hot spots, etc.
Otherwise....
http://m.ebay.com/itm/172181168655
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old August 6th, 2016, 01:15
They both have pro's/con's but for my Jeep I would have a much better comfort level with iron!
Otherwise....
I never worry about the price if I'm getting what I pay for! The Hesco is basically the same price as the Edelbrock but comes with matched int/exh ports and chambers.
As far as your Ebay head, it's about the same price as the rest of the fully loaded heads.
Old August 6th, 2016, 01:17
cal's Avatar
cal cal is offline
I wouldn't, aluminium has too many advantages.
Call Russ Pottenger and discuss options with him. He may have a TUPY head to sell or make you a deal on a good rebuild head, or convince you to go aluminium - either way, he's the subject matter expert here.
Old August 6th, 2016, 01:26
I'm sorry but I don't know who he is?
Old August 6th, 2016, 10:24
JohnX's Avatar
Sarge <3 Ben
Screen name is Russ Pottenger
Johnx is #1
Old August 6th, 2016, 10:28
cal's Avatar
cal cal is offline
Sorry, I forget you haven't been around much lately.
Russ is the local favorite (and the premier) engine/stroker builder, and he's always willing to take a few minutes to answer questions for members who need it.
Russ Pottenger
Bishop-Buehl Racing Engines
531 N. Lyall Avenue
West Covina, California 91790
Work (626) 967-1000
Fax (626) 967-7836
Cell (626) 673-2203
Email RussBnBracing@yahoo.com
Old September 14th, 2016, 09:50
So I purchased and received my new 0331 head from CCH. It is supposed to be the new design, I was expecting to see a "tupy" casting mark, but it doesn't have one ???
Old September 14th, 2016, 09:55
cal's Avatar
cal cal is offline
I'm looking at their website and its somewhat confusing.
They are saying "NEW" cylinder heads - which, if they are new, would not say TUPY (tupy was the name of the company who cast the head) - but then they are expecting your core returned, which would imply they are rebuilt heads.
If its a rebuilt head and does not say TUPY, its the original flawed design.
I don't see on their website where you can specify a TUPY vs standard 0331 head either, though.
Old September 14th, 2016, 10:21
md21722 md21722 is offline
When you say CCH are you referring to Clearwater? I've always understood them to sell newly made heads in an improved design. Similar improvements to the TUPY head that Chrysler used, but not identical. I'm not sure why they want your core back, unless they wholesale them off or something like that. TUPY is a Brazilian foundry that Chrysler had make the 0331 "TUPY" heads.
Old September 14th, 2016, 10:41
That's part of the confusion, sold as new, new design, and no core charge.
https://www.amazon.com/BRAND-CHEROKE...+cylinder+head
Old September 14th, 2016, 11:12
Miller88's Avatar
Miller88 Miller88 is offline
Random question, but do they just magnaflux or something a cracked cast iron head, true it up and send it out?
Old September 14th, 2016, 13:58
ehall's Avatar
ehall ehall is offline
One of the local guys with an 00 TJ bought a CCH head, looked good, obviously new casting with thicker walls where it mattered, he's reported no problems with it.
my '91 beater rebuild
Which 0331 replacement head? Spenser OEM Tech Discussion 21 July 31st, 2016 22:11
Best 0331 head replacement midwestairgunner OEM Tech Discussion 11 May 26th, 2015 21:10
0331 head replacement activeshooter1 OEM Tech Discussion 1 February 17th, 2011 18:11
#0331 Replacement Options... TerryDean Modified Tech Discussion 15 December 11th, 2007 22:48
0331 head replacement Ben H For Sale: Private Party Only. XJ ITEMS ONLY 2 January 25th, 2007 17:38
