Old July 19th, 2016, 15:44
RCP Phx RCP Phx is offline
New issue, low to no oil pressure!
I had a extreme cooling system failure not to long back. To keep it short, I'm curios as to what bearing failure would be the first affected. At this time my thoughts are leaning toward the rods?
Old July 19th, 2016, 15:51
old_man's Avatar
old_man old_man is offline
Re: New issue, low to no oil pressure!
Before jumping to conclusions,
1) If you have a Fram filter, throw it away and get a good filter.
2) Change what ever filter you are running to a good one, such as Wix
3) Get a manual gauge and check. I have seen way too many sensors go bad over the years.
In the mean time, go with a heavier oil such as a 15w40 or 20w40.
The rear main bearing can have the biggest impact since all the oil goes up through there. Cam bearings tend to not cause much because they are loaded less. If the rods are worn to the point the pressure starts dropping, and if I could hear worth a damn any more, I would be listening for rod knock.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old July 19th, 2016, 16:09
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Good advice. I'd pull the filter to start with
Old July 19th, 2016, 19:09
It's not the gauge, I have owned this (and 4 others prior) since day one. It's a 2000 w/ 70k miles. Brand new oil change this weekend, always run Amsoil!
Old July 19th, 2016, 19:21
old_man's Avatar
When did this start and what oil filter are you running?
Loveland, Colorado
Old July 19th, 2016, 19:22
trippled trippled is online now
I would still verify with a manual gauge. There's a chance something is partially clogging the pick up tube, other than that sounds like a tear down. Is it noisy?
Old July 19th, 2016, 19:46
It started after the massive overheat, it was 118* ambient. Till then I was running 20low/60high when cold. After that it is 10/40 cold and after I drive about 10 miles(freeway) it drops to 0/30. If I hold a high idle it will maintain almost 10.
Old July 19th, 2016, 19:53
old_man's Avatar
For the moment, use a thicker oil.
Loveland, Colorado
Old July 19th, 2016, 20:53
Believe me I've considered it but, that's a bandaid! But it could buy me time till winter! I thought about a HV pump, but since I'm pulling the pan,
if I'm pulling the pan, I might as well replace all the bearings,
if I'm doing all that I might as well go thru the heads,
Get where I'm going with this !!!!!
Old July 19th, 2016, 23:15
gradon's Avatar
gradon gradon is offline
I bet you have a cracked 0331 head that has leaked coolant into the oil and has ruined the bearings.
Old July 20th, 2016, 08:32
I never found any traces of water in the oil. We'll do a sniffer test to check for any combustion traces.
Old July 20th, 2016, 10:09
Isn't it spun cam bearings that really affect oil pressure ?
If you're going to pull the pan it will probably tell that story although I'd try another sender/way to read the pressure to be sure before putting too much work in.
Could just be the oil pump or gears that turn it.
Old July 20th, 2016, 10:16
blakews2217 blakews2217 is offline
My dads 96 gc does this with his 4.0. Trail rig. It started after sitting at almost 90 degrease for 30-45 min. Lost oil pressure the whole time. As long as he keeps it reved it gets oil. I pulled the valve cover and found metal paste in the rocker ends. Now I traded my worn out 5.9 gc for a xj that me and him built a motor for. When he pulls the motor I'll go through it and see what failed. I have most of the tools to do it. When I do I'll post it up.
Old July 20th, 2016, 10:43
old_man's Avatar
My statement about using thicker oil is to prevent any further damage while you sort it out. If you are pulling the pan, looking at and possibly plastigauge on the bearings will tell you a whole lot.
Loveland, Colorado
Old July 20th, 2016, 11:14
I'm just trying to get a game plan together. I just spent 2k on it last week......
New Griffin Radiator
Rebuilt my LA's
and installed Ten Factory front axles
Oil pressure issue dirtyjerseyjeep OEM Tech Discussion 9 January 6th, 2013 13:13
Oil pressure issue MudfrogK5 OEM Tech Discussion 35 November 3rd, 2010 10:48
Pressure Issue? 89heepxj OEM Tech Discussion 2 June 10th, 2009 12:09
Oil Pressure Issue nhrocker OEM Tech Discussion 6 September 17th, 2006 12:31
Oil Pressure Issue Jeff-97XJ OEM Tech Discussion 2 April 28th, 2005 07:38
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
