Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Sierra Chapter
Sierra Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old May 21st, 2016, 23:33
clydefrog's Avatar
clydefrog clydefrog is offline
Clyde Frog Build Thread
I figured I shold start a build thread for my rig so I could keep track of everything I do to it. Have much more plans for it down the road.
Currently I have:
-1987 XJ
-Engine is a Chevy Vortec 5.3 and some light mods.
-Transmission is a 4L60E.
-Transfer case is stock NP231 with slip yoke eliminator and different input gear.
-Read diff Ford 8.8 (not built yet)
-Front diff D30 (not built yet)
-Lift is a mix of various stuff, Rough Country LA kit, Rubicon express 3.5" springs and coils. RE for all the little stuff too (brake lines, track bar etc).
-Procomp steelies with 30" Hancook tires, prolly only going to go 31" down the road.....we'll see.
Shooting for a good over-landing vehicle, shes coming along.
Still have a lot to do, like making the snorkel functional instead of just a CAI. Build thread on the engine swap: http://www.naxja.org/forum/showthread.php?t=1122847
Old May 21st, 2016, 23:40
clydefrog's Avatar
Re: Clyde Frog Build Thread
Currently don't have 4wd, the front diff is not re-geared yet. I have these goodies that I will be installing in the next couple of weeks though (piecing it together). Chromoly axle shafts to eliminate the disco axle shafts. Trutrac differential with 3.73 gears to match the rear along with an install kit and disco block off plate. I have been on the fence if i should go 4.10's but it will tow 4,000lbs uphill in 3rd at 55mph with no issues so i think the 3.73 will stay. I'm at about 2,100 rpm's on the freeway. Also have a new diff cover to support the local 4wd shop, and to match the rear diff.
Old May 22nd, 2016, 23:21
#S194's Avatar
#S194 #S194 is offline
Sierra Chapter President
That Vortec engine is a tight squeeze. Looks good, looking forward to seeing your progress.
Originally Posted by GordoSmasho View Post
Tim's junk is impressively beefy. TWSS
Old May 23rd, 2016, 22:43
clydefrog's Avatar
Installed a aluminum expansion tank from Macs radiator. Highly recommended for peace of mind.
And I needed a smaller windshield washer reservoir to fit, got this off Amazon for $20 and the w/s washer motor that came with it was plug and play to the Jeep wiring connector.
Old May 23rd, 2016, 23:15
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
those struts aren't for an XJ though .... building a yota or something?
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old May 24th, 2016, 09:15
clydefrog's Avatar
oh...haha, No those are for my wife's BMW E90. I put them on this last Saturday. I REALLY wanted to do my re-gear on the D30 but the wife's car takes priority over the Jeep......
Old June 12th, 2016, 22:29
clydefrog's Avatar
Finally got around to re gearing the front D30, installing the Trutrac and chromoly one piece shafts.
Out with the old:
Took 4 tries. This is what I ended up with; I was pretty happy.
Now I have a slight pull to the right. I am going to throw it on the alignment machine this week to see whats up since i had the tie rod off. Hopefully its just a toe adjustment and not a radial pull from the new components.
Old June 13th, 2016, 07:13
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Got a link to that washer fluid reservoir? My DD MJ needs one.
Cool build. I've thought about building a nice overland jeep sometime in the future, but I think I'd struggle to keep it nice.
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old June 13th, 2016, 08:36
clydefrog's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I didn't have the right axle seal for the new one piece axle. I installed the regular two piece seal and sanded the axle on the seal surface. That obviously didn't work as a have a really small seap. Going to WFO today to see what they have for a seal. There was no machined surface to press a seal into on the passenger side and the standard seal (same as drivers side) did not fit.
Old June 13th, 2016, 14:21
clydefrog's Avatar
Alignment was spot on, tire pressures good, I even re-torqued the axle nuts. Still has a slight pull to the right. I wonder if that is an inherent trait of the Trutrac? Everything looks good, pull was not present before the swap.
Time to put my thinking cap on.
Old June 13th, 2016, 14:27
So for that new washer bottle all you had to do was splice into the current wires? Hmm. I might grab that too then. I keep smashing my Fender bottle on my late model...
Old June 13th, 2016, 23:08
clydefrog's Avatar
Actually the XJ factory plug was a perfect fit. It plugged right in and the factory washer hose was perfect size too.
Old June 29th, 2016, 15:53
clydefrog's Avatar
Fixed the pull! Turns out the Trutrac just needs to be broken in (I guess), it slowly diminished after ~300 miles.
I have been out wheeling the past two weekends. Went to Sawmill Pond OHV area and did some obstacles that where certainly pushing my skills. Learned a bit about the XJ as well.
Sawmill OHV area:
Also took it up to the top of Signal Peak, the hard way. With the 30" tires I was dragging the rear diff over rocks often. Traction was never a problem though, even in the muddy sections or the snow (yes there was still snow up there last weekend). A stock XJ could do this trail...with the right driver.
Need to figure out a solution to keeping the jam nuts on the RC long arm kit from loosening.....
Old June 29th, 2016, 16:13
thanks for pics!
where is sawmill OHV area ?
Also for the jam nuts, use blue locktite or tack weld them.
Old June 29th, 2016, 16:47
clydefrog's Avatar
thanks for pics!
I tried the lock tite, Maybe I will tack them (I am only having a problem with the left main arm one).
Sawmill Pond OHV area is on Lake Tahoe BLVD about 2 miles from the
"Y" (hwy 50 and hwy 89 junction) in South lake Tahoe. It is clearly marked with man made obstacles ranging from easy (blue signs) to difficult (black signs). I found it by accident while camping at Fallon Leaf campground. Awesome area to practice! Some of the obstacles looked beyond my Jeeps ability and my ability.
Rate This Thread:
O.K. B's Build Thread OutkastBoss Midwest Chapter 171 October 23rd, 2016 18:48
Another xj build thread scsmxj Modified Tech Discussion 4 April 6th, 2012 19:41
my 91 xj build thread Vanimal Modified Tech Discussion 68 March 25th, 2012 19:22
New to the thread/ New build kybray44 Sierra Chapter 5 March 8th, 2010 23:04
The build thread DutchVDub Colorado Chapter 101 March 15th, 2009 10:25
