Old July 7th, 2016, 20:50
racer32's Avatar
racer32 racer32 is offline
Re: 96 xj sport 5.3 swap
I used a TE Connectivity 32 pin connector for my gauge cluster. Digikey has a lot of connectors like that for not too bad of prices if you can't find one at the JY
Old July 8th, 2016, 19:42
cleenrob's Avatar
cleenrob cleenrob is offline
engine is in!
Old July 8th, 2016, 20:43
racer32's Avatar
Awesome
Old July 9th, 2016, 13:21
cleenrob's Avatar
plugged in the harnesses today, its still a big mess, but its the kind of mess where i know where everything is haha
also cut the support out for the new rad, i decided im going to run a factory jeep 4.0 condenser for the a/c i wasnt happy with how much of the support i would have had to cut out, ill just stack a couple of oil coolers (trans/ power steering) in the open space next to the rad, which i still need to fab mounts for..
also the kwick performance bracket does not clear the steering gear box (durango box/c-rock spacer) ill wait till i get my trans mount in the mail till i figure out what im gonna do about it, im likely just going to move the pump up and drill new holes ive got some space to work with. it just depend on the angle of the dangle, i think the main issue is the bracket moves the pump up and over ..but not up enought, but everything clears to hood at least
also i some how managed to dent the hell out of the tranny pan and punch a hole in it when i drop the motor in yesterday and didnt notice it till this morning
Old July 9th, 2016, 13:26
TRCM's Avatar
TRCM TRCM is offline
Is there room to move the alternator down & towards the center some ??
I notice that always seems to be the high point on these v8 installs........
Old July 9th, 2016, 13:32
cleenrob's Avatar
the bracket im using does that and the alt clears the hood just fine, the issue im having is with the power steering pulley not clearing the steering box.
i kew going in that the truck bracket wouldnt clear the hood
Old July 9th, 2016, 13:39
TRCM's Avatar
I got the problem you were having, was just asking if the alt could also be moved....
Looks like moving the alt in & down would help with hood clearance, and give enough room to the reservoir for the PS pump to move out & up to clear the steering box.
How hard would it be to put the alt over where the idler pulley is on the pass side, and then move the PS pump up ?
Just kinda thinking out loud and asking cuz I am looking at doing this too soon to my 96 sport.
Old July 9th, 2016, 13:46
cleenrob's Avatar
not to hard but i should have enough space to move the pump up enough to clear, if thats not enough ill press on a smaller pump pulley
Old July 9th, 2016, 13:47
PhotoJared's Avatar
PhotoJared PhotoJared is online now
The alternator is too thick to move in front of the head. There are different bracket companies out there. Mine are from LSBrackets and fit fine, It just uses a different style power steering pump.
Old July 9th, 2016, 13:51
TRCM's Avatar
Again, just asking, but if the belt is parallel to the front of the block, and the alt fits in front of the drivers side head, then it should fit in front of the pass side head.....of course, with different brackets.
I may have to keep it on the drivers side for an A/C compressor...gots to have my A/C.
Your brackets look like they clear everything better tho
Old July 9th, 2016, 13:52
cleenrob's Avatar
yea your bracket definatly clears way better than mine
Old July 9th, 2016, 13:55
cleenrob's Avatar
im sure it could but i dont know of any brackets on the market that do that, however if you have fab skills you can make the accesories do whatever the hell you want
Old July 9th, 2016, 14:01
TRCM's Avatar
I've had to do that before on other vehicles, but it's a PITA if they don't line up 100%....much easier to use proven stuff if it is available....
Old July 9th, 2016, 16:10
the_midwesterner the_midwesterner is offline
Look up goatbuilt LS brackets and dirty dingo brackets, they have options to swap alternator and P/S to the opposite side. The brackets depend on the the P/S pump you want to run.
Old July 9th, 2016, 16:47
TRCM's Avatar
awesome....thanks....I'll look into that
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 23:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 09:57
4.0 0331 Head Swap '00 XJ Sport ihscoutlover OEM Tech Discussion 80 November 6th, 2013 10:55
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 21:26
Will a 1990 XJ Laredo T-Case swap into a 1994 XJ Sport? ItZaJeePThiNG Modified Tech Discussion 6 February 1st, 2009 11:02
