Old November 20th, 2015, 09:26
F.N.G. F.N.G. is offline
Expedition Build: Yellow Jeep XJ
Now
This is my XJ Expedition Project.
Then
That was my stock 2001 Jeep XJ...
Backstory:
This is my first real Jeep Project.
When I got the jeep the previous owner had installed a 3inch Suspension lift with 2inch spacers on the front and 2 inch Lift Shackles on the rear, sitting on 31inch tires.
He provided me with a picture of the vehicle stock, before the lift.
Everything else was stock, including the broken Sway Bar links.
It had a death wobble from hell, which I found out the hard way on the highway coming home after buying it.
Once we hit 40 mph and a bump, it shock extremely violently until it came to a complete stop.
The experience was like an 8.7 on the Richter Scale, inside a giant paint shaker, while trying to steer.
Any of you that have experienced an actual legit full fledged Death Wobble in all it's glory know what I'm talking about.
And I still had a 2 hour drive home from the sellers house...
So it was at this point that I decided to strip it down and start from scratch in regards to the steering and suspension components.
How it sat when purchased
Phase: 1
We worked on it slowly, a little bit each day.
I don't have a shop, so we worked in my driveway, weather permitting.
We diagnosed many of the causes to the "Death Wobble" symptoms through trial and error.
One of the by-products of lifting a Jeep Cherokee 5 inch with no modifications or upgrades to the stock steering or suspension.
We would be removing the present lift in favor of a long arm lift kit.
I also started prepping for some of the exterior mods we would be putting on as well.
Front/Rear Bumper Removal
Parts List
I started ordering parts, and one by one they began collecting on my front porch.
Once my porch was full, parts began collecting inside.
We were living in a Jeep Parts Shop, and kind of interesting.
Here is my part's list bellow
Suspension:
  • RC 4.5 inch Long Arm Lift Kit:
  • Lifted high flex coil springs
  • Long arm Crossmember
  • Adjustable upper control arms
  • Adjustable lower control arms
  • Transfer case skid plate
  • Sway-bar quick disconnects
  • Adjustable track bar
  • Pitman arm
  • Stainless steel braided brake lines
  • Full Leaf Spring Packs
  • Performance 2.2 Series Shocks)
  • Rear Leaf Spring Shackles
Steering:
  • New bearings,
  • Moog upper and lower ball joints.
  • Currie Currectlync Heavy Duty Tie Rod and Drag Link.
  • Steering Box Brace.
  • Upgraded Heavy Duty 2.2 Steering Stabilizer.
Brakes:
  • New Rotors, Calipers and pads in front.
  • Drums and shoes in rear
Tune Up:
  • Air Filter
  • Champion Copper Plugs, and wires.
  • Oil change Mobile 1
  • Change transmission fluid
  • Coolant flush and fill
  • New Thermostat
Drive Train:
  • Slip Yolk Eliminator
  • Custom Tom Woods Rear Driveshaft
Exterior:
  • ARB Deluxe Bull Bar Front Bumper
  • Warn 8000 Winch
  • 2 IPF Spot Lights
  • JCR HD Rear Bumper/Tire Carrier
  • AJ's Super Rails Rock Slider
  • Roof Slider
  • JCR Gas Tank Skid Plate
  • Bushwacker Flat Fender Flares
  • Lower Rear Quarter plated on both sides
  • Underneath re-coated
Wheels:
  • 5 Cragar Soft 8 rims
  • 5 Goodyear Wrangler Duratrac 33x12.5 inch tires
  • Gorilla Chrome Lug and Lock set
Exhaust:
  • Custom exhaust from the headers back
  • Flowmaster Super 44 Muffler.
Miscellaneous:
  • Fixed wiring on driver side door, passengers can now control power windows again.
  • Fixed Rear Wiper.
  • New Windshield Wipers
Parts:
Phase: 1 Complete
Everything installed and tested.
After a little tinkering it road great.
Great articulation, good clearance, and no vibration at all.
The only thing steering/Suspension related that is still OEM in the vehicle is the actual sway bar itself, everything else was removed and upgraded.
The roof sliders had a bend to it, so we flipped them in the meantime until we straighten them out.
They are actually supposed to come down just above the door to protect the sides.
We had help from a shop installing the Lift and some of the equipment because we simply ran out of time.
The weather was upon us and we were working out of my driveway. So we put the project on hold and finished it in the spring.
Rough Country 4.5 Inch Long Arm Lift Kit
2001 Jeep XJ after Phase: 1 of the Expedition Build
More to come...
Old November 20th, 2015, 10:16
DieselSJ's Avatar
DieselSJ DieselSJ is offline
Re: Expedition Build: Yellow Jeep XJ
The 33's look good with that lift and the flares.
GadZooks Racing - Jeepspeed 1717
Brought to you by 4 Wheel Parts, Bilstein, Rubicon Express, General Tire, Rigid Lighting
http://www.facebook.com/pages/GadZoo...3613279?ref=ts
99XJ-4.0/AW4/242 87GrandWag-6.5 turbodiesel
Old November 20th, 2015, 18:01
chesterbuggle chesterbuggle is offline
How about some close ups of the roof sliders
Old November 22nd, 2015, 07:06
Bumper Integrated LED Reverse Lights
Installed LED spot lights in the JCR Rear Bumper, wired to my reverse lights.
Stock reverse lights were too obstructed by the JCR Rear Bumper to be of much use.
Decent lighting upgrade with major improvement for night visibility while backing up.
LED Reverse Lights
Old November 22nd, 2015, 08:09
BlurpleXJ's Avatar
BlurpleXJ BlurpleXJ is offline
Blue. Purple. Blurple.
Looks like a quality build. How do you like the Rough Country long arms? I decided to stick with short arm on a 4" lift, but went with OME springs and shocks.
1998 XJ "Roxanne": Stroked XJ pretending to be an expedition rig
Old November 22nd, 2015, 09:13
Luke95's Avatar
Luke95 Luke95 is offline
I have the rough country arms and so far so good. I am very happy with them.
Old November 22nd, 2015, 10:08
tom11919 tom11919 is offline
RC Long arms with Currie Johnny Joints here. Ride is soooooo much nicer than stock links (went directly from 4" springs and stock links to long arms).
Old November 22nd, 2015, 10:18
Luke95's Avatar
This is what I have as well and love
Old November 22nd, 2015, 14:16
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
You had some body work done. Did you do that yourself? I'm referring to the second to last photo in post #1.
In the photo where you took the rear factory bumper off, I saw rust on the rear quarter panel, and also, you'd have had to drill out the rivets holding on the bumper cover brace.
It looks like a clean repair, and good color match on the paint.
Dirk DeYoung--Member #176--National Vice President, SEC President
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2013 WKII (SUZIE)...2006 XK (TOW RIG)
Old November 22nd, 2015, 16:22
Ian Christiansen's Avatar
Ian Christiansen Ian Christiansen is offline
Near the top he says he did lower quarter armor. Maybe it's just covered up. Looks goood either way.
Old November 23rd, 2015, 08:44
Per your request
Roof Sliders
I picked this rook rack up second hand from a guy parting out his build.
Solid construction, simple rugged setup.
Strictly for side protection purposes as a roof slider setup, obviously not intended for sufficient cargo use.
Roof Sliders
Old November 23rd, 2015, 10:27
POSJ POSJ is offline
The roof sliders look upside down to me...Would they fit flipped over?
Old November 23rd, 2015, 10:50
Good eye. Yes the sliders were originally intended to be flipped, but
due to a bend in the sliders themselves the curve went opposite of the bodyline/roof.
Aesthetically speaking, it looked bad.
So until I could get them bent the proper direction we simply flipped them temporarily, and ended up liking the look of it so I kept it.
Old November 24th, 2015, 08:46
Personally I like the long arm set up much better than the short arm.
Better articulation and an all around better ride in my opinion.
Plus added protection underneath is a plus.
All in all I like the Rough Country Long Arm Lift Kit.
The arms, coils and leaf packs are good.
However I have already replaced the quick disconnect sway bar links and will be replacing the shocks with a more rugged alternative.
The quick discos failed multiple times with light use and broke on me fairly early. And the shock bushings are bad after a year of use.
Old November 24th, 2015, 15:02
We did have some body work done just on the lower rear quarter panels behind the rear bumper's plastic end caps.
I don't have a lot of experience with bodywork, so we had a guy that knew what he was doing help us out and do it right. Used thicker steal, so now it is armor plated on the lower rear quarters.
1996 jeep cherokee expedition/fishing build Jeepxjcountry Modified Tech Discussion 57 November 5th, 2016 19:02
Expedition build/body swap about to begin jeepingben Modified Tech Discussion 4 July 14th, 2015 06:00
Expedition Build ?s LYKOS Modified Tech Discussion 41 August 2nd, 2012 18:56
XJ Expedition Build 00'CherokeeXJ Modified Tech Discussion 32 November 28th, 2010 20:46
expedition trailer build question comrad_zeelaagee SoCal Chapter 27 February 9th, 2009 23:18
