clydefrog
- Northern California
So this is my first post, and a build thread in one. I started with a 1987 Cherokee base with a 5 speed and over 300,000 miles on it. It has been in my family since it was almost new. I learned how to drive stick in it almost 15 years ago so it does retain some sentimental value.
I wanted to post up my build so someone else could have some good technical info on doing this sort of swap. There are countless swaps on the net where people have put LS motors in XJ's, however, to the best of my knowledge (please correct me if I am wrong) no one has done it and made it California smog legal. For those of you who have done the swap, one headache and challenge i had to face was using an exhaust manifold that carried a carb stamp on it (carb = California Air Resource Board) and have dual factory cats that where no greater than 6" downstream of the manifolds. Like i said, many headaches (this is just one example). I will tr to cover the unique mods specific to California as best as I can.
Here is the before (sitting in my parents field for 3 plus years):
And here is where I am at currently:
Let me back up a bit. I built this rig for heavy off-roading (not much crawling), freeway driving and towing. A lot of extended expedition trips. So most of this build has been geared toward these goals. Here is what i have so far:
-2004 Chevy Silverado 5.3 Vortec with 4l60E transmission
-Factory Jeep NP231 with SYE and Novak cable shifter
-Custom drive shaft
-Ford 8.8 with drum brakes and 3.73 gearing and stock LSD
-D30 up front with true trac
-Rough country long arm kit with sway bar disconnects
-Rubicon express long AAL in the rear 4.5"
-Rubicon Express springs 3.5" plus a 5/8 spacer
-Rubicon express trackbar
-Quadratec 7.0 hydro shocks all around (not a fan of nitros or anything too stiff)
-SS Rough Country extended brake lines
-30" Hancooks on 15x8 procomps with 3.75" BS (prolly going to go with a 32" when these wear out)
That is pretty much it for the drive train, i will cover the little tidbits further in the post.
I spent a lot of time on this thing and constantly am being asked about it so i feel that i should share. Enjoy.
-Custom drive shaft
