Old November 7th, 2017, 23:12
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Re: Projext "V8 XJ" Build
Originally Posted by clydefrog View Post
Yes!
I like how you are using my 'ear plug' trick. Buy a bulk pack and use the rest for your un-prepared friends when you go shooting!
Cross-member stinks?
Lol I knew someone would notice that.
I have IRO long arms and I boogered the holes when I drilled it for the LS trans mount.
Old November 8th, 2017, 06:19
cleenrob's Avatar
cleenrob cleenrob is offline
for the t-case adapter it helps to coat the survace the t-case input seal sitts against with rtv. i did that along with the ear plug trick and havent had an issue..with that leaking at least
Old November 8th, 2017, 11:44
PhotoJared's Avatar
I have the entire seal coated right now with permatex red and it still leaks.
I picked up some Mopar RTV that I'll be using this time.
Old November 8th, 2017, 23:56
PhotoJared's Avatar
Should I run 2.5" or 3" exhaust?
Old November 9th, 2017, 00:16
indian's Avatar
indian indian is offline
I run 2,5" to Y-pipe and then 3" to catalytic conv. and muffler
Old November 9th, 2017, 11:35
clydefrog's Avatar
clydefrog clydefrog is offline
2.5" is what I run, did a lot of testing. No real benifit to running 3" with a stock 5.3. I also have a dump right after my cats and I have checked fuel trims and MAF readings and they are the same at WOT both with the exhaust dumped and running it all the way out the back. My guess is maybe a 10hp loss at anything over 4k rpms but really have nothing to back that statement up. I would run 2.5" for ease of install and long term longevity (rock clearance etc).
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old November 9th, 2017, 13:10
burntkat burntkat is offline
NAXJA Member #1145
Anyone know a source for that y-pipe, non-stainless?
EDIT: nevermind, surprisingly inexpensive at Summit, and on the way...
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old November 10th, 2017, 00:54
PhotoJared's Avatar
If I were to build an exhaust any Idea on what bends I would need for the header back?
I think I'm going to do 2 1/4" from the header to a 3" collector and back.
Old November 10th, 2017, 02:15
PhotoJared's Avatar
Just ordered a Hobart 210MVP, Evolution Rage 3 chop saw, 2lb spool of stainless wire, and some welcome welding PPE.
I'd like to build a welding cart and a welding table so I have some work surfaces.
Old November 11th, 2017, 21:08
cleenrob's Avatar
i used 2 of these for the down pipe into a 2.5 to 3 Y
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old November 12th, 2017, 10:30
PhotoJared's Avatar
Ordered everything for the header back exhaust. I'll be learning how to weld on exhaust pipe. Here's to hoping I don't Fail!
Old November 12th, 2017, 13:18
PhotoJared's Avatar
Oh, and i ordered everything in 304ss. I may end up just tacking and having someone TIG it.
Old November 12th, 2017, 23:39
PhotoJared's Avatar
Gosh. Why are LS1 intake manifolds so expensive??
Old November 13th, 2017, 00:39
indian's Avatar
the early LS1 (97-00) manifolds are not so expensive. but the late LS1 (01-) are the same like LS6 monifolds and they are expensive.
I bought the early LS1 for 200,-
Old November 19th, 2017, 19:58
racer32's Avatar
racer32 racer32 is offline
Good looking setup. I'm using the same style manifolds. I wish I would have used V-bands.
Because everyone figured out that they make nearly the same power as a $400 FAST intake.
97-01 I think are all the same. LS6 are 02-04. I've gotten lucky and picked up a couple 97-01s locally for under $200. I use a Craigslist notification extension for Chrome Checks for what I am searching for every 5 minutes.
PS:
Don't forget about Speewday Motors:
https://www.speedwaymotors.com/Combo...nch,67444.html
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 275 February 5th, 2018 15:59
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 23:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 04:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 03:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 13:19
