Old September 6th, 2016, 17:51
ftwelder's Avatar
ftwelder ftwelder is offline
Re: Projext "V8 XJ" Build
if the input shaft of the T-case doesn't go into the trans far enough you end up with leak due to one of the two seals (one trans and one t-case) not sealing on the OD of the Tcase input shaft. I had that problem when I added a flip ring between the tcase and tranny. I used a "seal saver" kit to extend the input shaft sealing surface.
endless jeep project that will eventually end up as a rust bucket in someones backyard.
Old September 8th, 2016, 14:52
PhotoJared's Avatar
PhotoJared PhotoJared is offline
So I've come to the realization that the beast is not going to be finished to take it to Pismo. We move next week and we had to pay down a credit card which took all of my Jeep money. The rest of our assets are going to the new house and new furniture. I also have to get the garage packed up and ready to go. Looks like it's going on the back burner for at least a couple more months.
Looks damn good though!
Old September 8th, 2016, 14:58
racer32's Avatar
racer32 racer32 is offline
Lookin good buddy. It will get there. I worked on mine over 6 months and its still really not done yet. Good luck with the move.
Do you have a good size garage you are moving into?
Old September 8th, 2016, 15:10
PhotoJared's Avatar
Our new house has a 3 car garage. It has a 2 car and a single "swing" garage. So the single will be the workshop and the double for both cars.
I'm coming from a 2 car and the workshop takes up half.
Old September 8th, 2016, 15:11
cleenrob's Avatar
cleenrob cleenrob is offline
needs more tire
Old September 8th, 2016, 15:39
PhotoJared's Avatar
Originally Posted by cleenrob View Post
needs more tire
I have a buddy selling his XJ with Currie 9" axles. If he doesn't sell he's going to be parting out and I'll buy his whole suspension setup and be on 37"s
Old September 8th, 2016, 17:31
cleenrob's Avatar
im planning on sleeved/trussed/gusseted jk d44s with factory lockers and 4.56 or 4.88 gears
Old September 8th, 2016, 22:03
clydefrog's Avatar
clydefrog clydefrog is offline
So i took it for a little test spin.
It's leaking still. Not sure why. Maybe I jacked up that interior seal during install? I put a nice healthy bead of red RTV on the inside which should be the best at keeping oils in. Then again trans fluid is basically a solvent.
Not sure what to do. I'll probably call AA on Tuesday.
I did mine twice with poor results.
Its the second (not used) clocking hole on the AA adapter. I had the same problem, drove me insane! You need to coat an earplug in RTV for each of the clocking holes not used (or weld them shut). Its a wet trunion so it will constantly leak unless you plug the unused holes. Kind of a poor design on AA's part. It doesn't fit the NP231 case right, they shouldn't have used extra holes.
Looks awesome BTW. Just took mine to Burning Man and got 15.2 mpg towing a trailer! Pismo should be fun.
Old November 12th, 2016, 16:31
PhotoJared's Avatar
Alright dudes! 2 months since the last post on this! Unfortunately/Fortunately (you'll see) there havent been any updates to the Jeep. I'm finally getting settled in the new garage and figuring out where the tools work best.
I bought a new TV for the house too!
I promise i still have the Jeep!
So the reason for not updating this recently is because of this. My wife and I are having our first! She's due April 18 which puts her at 17 weeks.
We found out a couple of days ago what we're having! It's a boy!
Old November 12th, 2016, 16:33
racer32's Avatar
Congratulations man Nice house too.
Old November 12th, 2016, 22:03
XJwonders XJwonders is offline
Huh, what?
That's awesome! Congrats!!!
Old November 13th, 2016, 13:41
PhotoJared's Avatar
Thanks Bros!
Old November 14th, 2016, 10:55
R6TeXJ's Avatar
R6TeXJ R6TeXJ is offline
Congrats on the lil man! and pimp house dude!
Old November 25th, 2016, 14:14
CharlieG82's Avatar
CharlieG82 CharlieG82 is offline
Just read through this whole build, dude AMAZING WORK!! I've been researching for the last couple weeks on doing an LS swap; a buddy just did it to his YJ, I'm hooked now. I'm a college student so I'm going to have to save up for everything before I even attempt this. The one area of this build that has me so intimidated is the wiring... I have very small knowledge of how wiring even works, I've installed an audio system and that's about it and a couple lights on my motorcycle that's how far my wiring knowledge goes. Is the wiring even that hard? Or just really in depth?
Old November 25th, 2016, 15:49
racer32's Avatar
The wiring can be as hard or easy as you want to make it. If you do the bare minimum to the harness and use a separate fuse/relay block its not overly difficult. I went nuts and integrated it into the jeep harness quite a bit and used the jeep Power Distribution Center to run everything.
Lots of info on lt1swap.com. Start there.
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 234 Yesterday 19:53
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 23:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 04:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 03:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 13:19
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
