Old September 5th, 2015, 05:17
ehall's Avatar
ehall ehall is offline
Re: Projext "V8 XJ" Build
good looking shelf, ask around for some scrap linoleum
my '91 beater rebuild
Old September 5th, 2015, 08:03
westvirginia24976 westvirginia24976 is offline
Also a sheet of sheet metal works well, but do cover that bench top.
Old September 5th, 2015, 16:06
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Thats a good idea!
I thought about sheet metal too, but its 'cold' and I don't weld.
I actually thought about covering it with a gym mat material. Its super heavy and durable. We'll see
Old September 12th, 2015, 01:24
PhotoJared's Avatar
How to - De-Pin the C107 connector -
The C107 connector is the only connector to integrate the body harness to the engine harness. It sits just to the left of the oil filter in the back of the engine bay. I couldn't figure out how to de-pin the connector until I finally got some smaller screwdrivers.
This is what the connector looks like. You start by removing the back cover and the rubber insulator piece. They'll just slide back but remain on the wires. It's easy to remove the cover (you'll figure it out)
The inside of the connector has this red piece. It needs to come out.
This is the back of the connector. The way it's designed it looks like you can remove the wires from the back, I could not. The very top left hole (and the one below it) is the retaining clip for the red piece. Just press down on the second hole down. The red piece has little arms that stretch down the side of the connector (you're just pressing on these). The red piece will start to come out. Press an even distance on each side of the red piece so it doesn't bind up.
There is a small retaining piece that needs to be held up to remove the wire. Just hold it up and pull the wire from the back. It should slide out.
Remove your unneeded wires and put the connector back the way you took it apart!
Old September 22nd, 2015, 15:46
PhotoJared's Avatar
Cant wait until next paycheck! Its going to be an ordering frenzy!
Old September 27th, 2015, 11:53
PhotoJared's Avatar
Ordered the radiator and a 17lb cap. Should have it in about 3 weeks.
http://www.summitracing.com/parts/gri-1-28182-tls
Old September 27th, 2015, 15:25
yossarian19's Avatar
yossarian19 yossarian19 is offline
Originally Posted by John D View Post
I wouldn't consider the 4.8 as an option, it's a lot of work for a small gain.
Hmm. I don't know how the power bands compare but the 4.8 with a cat-back & a tune makes +100 HP & +65 ft-lbs before you've touched a wrench to it. Not sure you could install a 4.8 any cheaper than you could build an equivalent stroker but I'd be glad to have one in an XJ anyhow.
Old September 27th, 2015, 18:05
John D's Avatar
John D John D is offline
NAXJA Member # 788
You're going to do the exact amount of work as you would for a 5.3 or 6.0 and get a slight gain over the 4.0.?
Makes sense, good luck.
Reread the post- I wasn't comparing a 4.8 to a stroker., I was comparing a 4.8 to a 5.3 or 6.0.
Old September 27th, 2015, 18:08
PhotoJared's Avatar
The price difference between a 4.8 and 5.3 is pretty negligible. The difference between a 5.3 and 6.0 is greater.
I've pretty much narrowed it down to using the 5.3. I'm going to try and find a 5.3 with year matching 4x4 transmission.
Old September 27th, 2015, 18:13
John D's Avatar
NAXJA Member # 788
If it's possible to do, go for the 6.0. I've tuned mine as far as I cam and now I'm looking at cam and heads for more. I guess it depends what your doing and who you're riding with. The guys I play with outrun me with LS1s and 6.0s. I wish I had more than I do with the 5.3
Old September 27th, 2015, 18:27
PhotoJared's Avatar
Do you think a 2001-02 DBW LS1 would be worth it? Prices look fairly reasonable for them...
My only hesitation; I'm trying to complete the swap for <$4500 total. Price is a concern. I don't mind spending money if i need to, but I don't want to end up just spending out the ass.
Something like this: Worth it?
http://www.ebay.com/itm/1999-Chevrol...d3e046&vxp=mtr
Old September 27th, 2015, 21:19
The major difference between a 5.3 and a 5.7 is bore, and the 5.3's iron block can be opened up. The LS1 has a different accessory drive setup & intake manifold, yes, but the engines are very similar when you are down to the long block.
The "car" LS motors only make financial sense if they are needed for a smog legal swap or are going in something that handles. Also - once an LS1's bores need to be re finished, the block is usually done for.
I disagree that 100 HP and 65 lb-feet is a "slight" gain but hey, that's just me. Sounds like John is really hauling the mail
Old September 27th, 2015, 21:29
blistovmhz blistovmhz is offline
You can usually pick up an 05 5.3 with 4l65e trans for $500. LS will cost way more. If you have a budget and aren't looking for monstrous power, the 5.3 is a very good option, and can make a lot more than stock LS power for an extra grand. Either way, the 5.3 has a better power to dollar ratio. It just won't make 700hp.
Old September 27th, 2015, 21:38
PhotoJared's Avatar
The one reason a ls1 is compelling is because the intake will clear the XJ hood. I'd really like to not cut my hood. I was kind of already accounting for a LS intake.
Where the hell do you find a 5.3 for $500?
Old September 27th, 2015, 22:07
Canada? Maybe this is the one thing that we can get here for cheaper than the US? When I did my swap, I had no problem finding 5.3's with tranny's for under $750 from 02-07.
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 268 January 15th, 2018 18:38
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 23:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 04:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 03:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 13:19
