Old July 28th, 2016, 15:34
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Re: Projext "V8 XJ" Build
Originally Posted by racer32 View Post
Can't you swap wires around on your current relay?
Yea I could, but I'm just using the stock Jeep relay. So opening up and changing the bottom of the relay box is a pain in the ass.
Old July 28th, 2016, 15:45
racer32's Avatar
racer32 racer32 is offline
Yes it is. I took mine apart several times. All the retaining tabs are brittle as hell too. I only broke 1 thankfully.
Old July 28th, 2016, 16:17
PhotoJared's Avatar
So I don't think just adding the GM fuel level to the jeep one works. Maybe I need what was suggested, but with the jeep off the GM fuel level shows 43%. With the jeep on it shoots to 100% I may just end up doing what clydefrog did and doing a switch on the fuel level with resistors. One side at full tank and the other at half.
Old July 28th, 2016, 16:23
PhotoJared's Avatar
Is this what I'd need??
150 ohm (for half-ish) tank:
https://www.radioshack.com/products/...ant=5717272389
40 ohm for full tank:
http://www.newark.com/vishay-dale/cw...10w/dp/65K3660
Old July 28th, 2016, 16:29
racer32's Avatar
I used an aftermarket sender and guage so I'm no help on this one.
Old July 28th, 2016, 17:00
clydefrog's Avatar
clydefrog clydefrog is offline
I will send you a mock harness with the resistors in it and a switch (replica of mine, I have a ton of extra resistors) if you want. PM me your info. What year is your GM ECU? There were different OHM ratings depending on the year.
Old July 28th, 2016, 17:31
PhotoJared's Avatar
Wow serious? Thanks! I'll PM you my info.
It's a 2005 harness. Off the top of my head it's 40 ohms full 270 empty.
Thanks a lot that's very generous of you.
Old July 29th, 2016, 01:58
PhotoJared's Avatar
Just wanted to share a quick video:
https://drive.google.com/open?id=0By...VJpSkpqZWVQMjQ
Old July 29th, 2016, 05:47
John D's Avatar
John D John D is offline
NAXJA Member # 788
It's been awhile so I'm not 100% sure how I did it, but I am using the Jeep relay to run the fuel pump. I get my trigger from the GM PCM, I'm pretty sure I just brought that over as the ground on the relay. I could be wrong on how I did that, but I am using the Jeep relay without issues.
Old July 29th, 2016, 13:51
PhotoJared's Avatar
I grabbed the brown wire coming out of the C3 at the PCM. that's the fuel pump relay wire. The GM gives power though and the Jeep triggers on negative.
PhotoJared's Avatar
Gas tank is mounted up!
Old July 29th, 2016, 14:34
cleenrob's Avatar
cleenrob cleenrob is offline
yup, my plan was to ground the jeep relat wire and send the gm signal to the 12v switched side of the relay
Old July 29th, 2016, 17:06
PhotoJared's Avatar
So weird issue is back again.
I hook the GM fuse box into a relay. I trigger the relay with the battery. Everything works. Pedal works. Jeep actually runs pretty well.
Hook the same relay trigger into the jeep coil power wire. I get no pedal. I found out why. The coil wire is triggered using the ASD relay.
Now same thing again but the trigger is hooked into the cig lighter power wire. I get pedal now, but no spark.
Weird issue. Again if I hook the relay trigger directly to the battery it works perfectly.
Suggestions?
Old July 30th, 2016, 13:05
PhotoJared's Avatar
Suggestions?
I know I'm quoting myself on this, but is there a keyed ignition that stays on with the key in the "run" and "start" position? I wonder if the coil and cig lighter relays I tried are somehow not functioning in the "start" position.
If they're not i'm just going to run a switch to the battery and any time I turn on the jeep I'll flip the switch to start up the GM PCM. It'll basically be an ignition switch...
I know it should run off an ignition positive source but I just can't figure out why. The guy who did my wiring harness just said "it must be an issue with the Jeep wiring". Thanks dude.
**EDIT - I wonder if there's a key+ that powers up the Jeep ECU. I'll have to check if that wire would work to trigger the GM fuse box.
Old August 1st, 2016, 23:52
PhotoJared's Avatar
*facepalm*. I just looked at the ignition switch wiring. I didn't even realize it was in the manual. I can't believe I missed it. So fuse 8 at the junction box is a spare fuse and is on with run and start. So I ordered some mini fuse taps and we should be all good.
Man do I feel stupid
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 268 Yesterday 18:38
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 23:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 04:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 03:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 13:19
