Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old February 2nd, 2015, 10:12
PacificEd's Avatar
PacificEd PacificEd is offline
Regular Joe
Renix head in stroker build
I'm working to make a plan of what to do about my worn out 1988 Renix engine. One of my options is to build a stroker engine.
After doing a lot of reading it seems like almost everyone uses a HO head on their build. To keep things relatively simple regarding the TPS, intake and throttle body, I'd like to use the Renix head. Is their anything wrong with using it other than it won't flow and make as much power?
I'm wanting to build a good solid engine that will run on 87 pump gas and be reliable and work with my existing Renix electronics.
I have a 12 wt 258 crank and rods already.
Thoughts?
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old February 2nd, 2015, 10:52
gradon's Avatar
gradon gradon is offline
Re: Renix head in stroker build
If keeping the renix tb, definitely get it bored out to 60mm.
Old February 2nd, 2015, 15:31
PacificEd's Avatar
Regular Joe
I've got several extra throttle bodies. Who and where do you recommend to get one bored out?
Old February 2nd, 2015, 15:45
gradon's Avatar
Jeff Leigh at Leigh Performance Machine. www.strokedjeep.com
Old February 2nd, 2015, 20:17
PacificEd's Avatar
Regular Joe
What is the stock dish on the H802CP pistons? Jeepstrokers says 15.5 cca while another book says 13.4. I'd say 15.5 since Jeepstrokers is the authority but I just want to be sure.
I'm trying to figure my SCR and DCR.
Old February 2nd, 2015, 20:50
gradon's Avatar
I didn't measure mine, but my research years ago found that the 802s and 825s had 15.5cc dishes.
Old February 2nd, 2015, 21:07
PacificEd's Avatar
Regular Joe
I made my first official post on Jeepstrokers to see about my numbers.
I came up with a SCR of 9.71 and a DCR of 7.13.
http://www.jeepstrokers.com/forum/vi...hp?f=15&t=4775
Old February 2nd, 2015, 22:01
David_Bricker's Avatar
David_Bricker David_Bricker is offline
PSR Fire Marshall
Talk to Russ Pottenger. He built the 4643 motor, which is using a Renix head. Perhaps Cal will weigh in as well.
David Bricker / SYR
Gomer - '95 XJ, 2 dr. 4.6L Russ Pottenger Stroker; Novak TJ AX-15; Black Box 2.72:1 + 241OR 4:1; RockJock 60 Front, hydro assist, Hi-steer; D60 trussed and shaved rear; 4.56 ARB Front and Rear; Black Magic discs, Bilstein 7100s front and rear; 35s; PRP seats; Warn PowerPlant winch. Annd, the Faux Dorkle is gone.
National Treasurer 2013-2019
Not a member? Become one today, and help support YOUR club.
Old February 3rd, 2015, 05:02
PacificEd's Avatar
Regular Joe
My quench was .0645 for the above formula. Looks like that is premium fuel only. I've got to play more with the numbers to get the quench down to .035.
I hate to waste Russ' time since I don't have the funds to buy a motor from him. I had no idea that the 4643 XJ was running a Renix head. That is pretty encouraging.
Rate This Thread:
Renix or HO head gasket for renix head on HO block? Mike1331 OEM Tech Discussion 20 April 8th, 2013 22:14
Renix 4.0 head needs replaced, any 4.0 head work? BoostedYack OEM Tech Discussion 5 January 9th, 2010 21:11
99+ Intake onto a Renix head with Renix exhaust BIGSLVRXJ Modified Tech Discussion 6 March 19th, 2008 19:29
Stroker with Renix head and intake profonde Modified Tech Discussion 4 November 14th, 2006 07:49
Hodge's Renix Stroker Build up. HodgePodge Jeep Street and Performance 17 February 8th, 2005 15:06
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
